# 10 ct Gong v2 Mast Clamp (63100 + 651xx)
**URL:** https://foil.zone/t/10-ct-gong-v2-mast-clamp-63100-651xx/24798
**Category:** efoils – Electric Hydrofoil Surfboards
**Created:** [September 1, 2025, 1:41pm UTC](https://foil.zone/t/10-ct-gong-v2-mast-clamp-63100-651xx/24798 "2025-09-01T13:41:44Z")
**Showing post:** 1
### Author: ![DanDyse](https://foil.zone/user_avatar/foil.zone/dandyse/32/24709_2.png) [@DanDyse](https://foil.zone/u/DanDyse)
#### Post date: [September 1, 2025, 1:41pm UTC](https://foil.zone/t/10-ct-gong-v2-mast-clamp-63100-651xx/24798/1 "2025-09-01T13:41:44Z")
I know there are quite a few designs, variations, versions … after countless modifications I’m sharing my clamp design for mounting a Flipsky 65121 (or similar) or a 63100 to a Gong v2 mast: simple yet strong. I call it the “10 ct clamp” because an important part of it is a coin: a 10 ct Euro, a Dime or anything around 20 x 2 mm will fit. It withstands all the force, the plastic just holds everything in place.
Apart from a 3d printer, you will also need (63100):
- 4x rods length 140 x 4 mm
- 4x M4 nuts + 4x M4 self-locking nuts
- 2 screws for wood / self drilling, 12 x 2 mm
- a clamp made of metal sheet
Or analogue for 651xx:
- 4x rods length 140 x 5 mm
- 4x M5 nuts + 4x M5 self-locking nuts
All stainless steel of course. I’ll let the images speak for themselfs. If you have questions, let me know. Here ([63100](https://cults3d.com/en/3d-model/various/10ct-flipsky-63100-gong-v2-mast-clamp-for-efoil)) and here ([651xx](https://cults3d.com/en/3d-model/various/10ct-flipsky-651xx-gong-v2-mast-clamp-for-efoil)) are the 3d-files along with detailed description how to mount. I have used 0.7 mm metal sheet, this is more than strong enough and still can be cut, drilled and bent as needed by hand.
63100:
 ![63100 - 1](https://foil.zone/uploads/default/original/3X/0/f/0faa8d92f4d53e492668ba84c8d0ff86fdefd492.jpeg) ![63100 - 2](https://foil.zone/uploads/default/original/3X/0/4/0451f795a263ca240652afcdc210738702b1c246.jpeg) ![63100 - 3](https://foil.zone/uploads/default/original/3X/a/f/af5445b2385643632728a48036c098bdec922761.jpeg)
 ![63100 - 4](https://foil.zone/uploads/default/original/3X/7/5/757f6e6bc04a8c78fd64bd8ebc1b96df819312c4.jpeg) ![63100 - 5](https://foil.zone/uploads/default/original/3X/5/8/58e9a8294f82d660f7d91fafd7d07cf8754ce859.jpeg) ![63100 - 6](https://foil.zone/uploads/default/original/3X/4/4/448c9f851eda4b3d6ea9a43aa1c267979ac785a5.jpeg)
651xx:
 ![651xx - 1](https://foil.zone/uploads/default/original/3X/0/c/0cd1f81a02728378ee087186d4aafcf0980dea2b.jpeg) ![651xx - 2](https://foil.zone/uploads/default/original/3X/f/8/f8c521dbfe4a2250aad7665015e1bb77a9fb4573.jpeg) ![651xx - 3](https://foil.zone/uploads/default/original/3X/3/a/3af7cd4f96f533555bc38ec279ec14209b434586.jpeg)
 ![651xx - 4](https://foil.zone/uploads/default/original/3X/a/5/a5a7aae42cbc114571b563e6dee43ca760e64adb.jpeg) ![651xx - 5](https://foil.zone/uploads/default/original/3X/d/a/da19ce779f4a0cf318d37ce3bdd4a39428dc364f.jpeg) ![651xx - 6](https://foil.zone/uploads/default/original/3X/8/a/8a1c87993c01939b548eefae804f4d52e7a8c16d.jpeg)
Here two more pictures of the actual metal clamp:
 ![0f3577a9-ac30-4ea5-a851-6baf77771bdd](https://foil.zone/uploads/default/original/3X/e/5/e570f988f10c0b56061c9d2a5dd6ec9bf4923768.jpeg) ![068d5ef5-6954-4d1b-94bf-d8d8253d753f](https://foil.zone/uploads/default/original/3X/0/9/09b634eb3d014a89f21443ecc3d6baeb33d61abc.jpeg)
Cheers!
_[View the full topic](https://foil.zone/t/10-ct-gong-v2-mast-clamp-63100-651xx/24798)._
