# 25 Kw Electric Jetsurf
**URL:** https://foil.zone/t/25-kw-electric-jetsurf/2143
**Category:** Electronics (ESC, remote, batteries)
**Created:** [July 13, 2018, 10:03pm UTC](https://foil.zone/t/25-kw-electric-jetsurf/2143 "2018-07-13T22:03:49Z")
**Posts on this page:** 9
**Page:** 1
<div class="post-metadata">
### Author: ![MattSheehy](https://foil.zone/user_avatar/foil.zone/mattsheehy/32/2905_2.png) [@MattSheehy](https://foil.zone/u/MattSheehy)
#### Post date: [July 13, 2018, 10:03pm UTC](https://foil.zone/t/25-kw-electric-jetsurf/2143/1 "2018-07-13T22:03:49Z")
</div>
Hey guys I have been doing a lot of reading on the forum but haven’t found anyone who has built a really successful electric jetsurf. I was doing some research and it looks like a lot of the company’s selling the commercial ones use a 24kw gas engine. I was thinking about using one of the massive 25kw 120mm alien outrunner motors along with a massive ESC to power the jet. This is the motor I was thinking about.
> **[120100/SW Sensored Outrunner brushless motor 50KV 25000W water cooled](https://alienpowersystem.com/shop/brushless-motors/120100sw-sensored-outrunner-brushless-motor-50kv-25000w-water-cooled/)**
Anyone have any ideas? Or think it would work?
Sorry this is not an efoil but I think it’s related.
Thanks for help,
Matt
### Author: ![Alexandre](https://foil.zone/user_avatar/foil.zone/alexandre/32/2884_2.png) [@Alexandre](https://foil.zone/u/Alexandre)
#### Post date: [July 13, 2018, 10:29pm UTC](https://foil.zone/t/25-kw-electric-jetsurf/2143/2 "2018-07-13T22:29:43Z")
</div>
i wanted to build a jetsurf before my efoil , i might do that next year, i have done a lot of research over the past 2 years about it, the way i would built is:
1 drive :
[https://www.mhz-watercraft.com/shop/en/jets/497/jet-64-for-electro-surfboards-max.-12-kw?c=110](https://www.mhz-watercraft.com/shop/en/jets/497/jet-64-for-electro-surfboards-max.-12-kw?c=110)
with this motor or tp, inrunners (for coolling issues)
[https://alienpowersystem.com/product-category/brushless-motors/100mm/](https://alienpowersystem.com/product-category/brushless-motors/100mm/)
chosse kv depending on nb cell, aiming for 16000rpm
esc ???
i would prefere 2 drives:
2 jets drives 52mm or 58mm
[https://www.mhz-watercraft.com/shop/en/jets/277/jet-52-booster-for-bodyboard-max.-3-3-kw?c=110](https://www.mhz-watercraft.com/shop/en/jets/277/jet-52-booster-for-bodyboard-max.-3-3-kw?c=110)
with 2 motor sss 56104 en 480kv working on 12S
esc:
2 heifi X pro 300A
8 lipo multistars 6S 20000mah
#### Post date: [July 14, 2018, 1:14am UTC](https://foil.zone/t/25-kw-electric-jetsurf/2143/3 "2018-07-14T01:14:41Z")
</div>
I thought these things needed more power but I guess I remembered wrong. The Race Titanium board which is the company’s most powerful board, shown below only has a 9.5 kw engine. And the most powerful gas jet drive I could find was 15kw one. I would like to find a motor that is close to these numbers but It’s hard to tell for most of the electric motors what the continuous wattage is I feel like most of them put the max possible wattage which can be pretty missconseaving. Does anyone have any tips on this?
 ![Screenshot_20180713-185521_Drive](https://efoil.builders/uploads/default/original/2X/c/caecd5c099d173b8410003359aba09d51721960e.jpg)
 ![Screenshot_20180709-224720_YouTube](https://efoil.builders/uploads/default/original/2X/d/d763a2386e5452e98dd1f2a96b3f88f6a069f38f.jpg)
I was initially thinking about using 2 drives as well with maybe 2 sss 360kv motors because I know veFoil has had some luck with them or something similar. I changed my mind because I feel like most of the time 1 big drive system is more efficient then 2 smaller ones. I know you were looking at the pre built ducts and I see that the 16000 RPM produces the most thrust so hitting that rpm would be good. Those ducts look sweet but a little to expensive for me and I think I’m going to try to make my own duct and impeller. Which is also why I only want one jet drive because that means less work. I was also looking at specs for jet skies and other jet powered boats and most of the time the rpm is around 5000 which I’m guessing is a good one. The jet drive boards above that I posted the picture of say there engines run between 6700 and 7700 rpm. So I’m going to aim for something around 5000 TO 7700 rpm I think. Not sure what kV I should get though because its definitely going to change when the motor is under load. Also with only having one motor I only need to get 1 really powerful ESC which might possibly save money… not sure. What makes you prefer 2 drives instead of one?
I would like to stay with outrunners if I can because they have high torque and low KV’s which means I can run everything at high voltages with out a ridiculous RPM. I like the higher voltages because that means less heat and greater efficincy I’m not sure how high I want to go though the motor has a max of 100 volts which would give me a good rpm but that high of a voltage kind of scares me. The biggest issue with outrunners for this application is the cooling because you can’t use a water jacket. The alian motor linked in the last post is water cooled which is cool even though it’s a little OP. Maybe I can find another outrunner that is still water cooled but less powerful or just make a really overkill jetdrive with the 25kw motor. Also what made you choose that battery capacity?
Also does anyone know how much thrust the commercial ones put out ? I know the one that you posted above with the dule set up could put out close to 50kg of thrust which seams like a pretty good amount but I’m not sure?
#### Post date: [July 14, 2018, 9:13am UTC](https://foil.zone/t/25-kw-electric-jetsurf/2143/4 "2018-07-14T09:13:00Z")
</div>
between what i have read and what i have done myself:
- outrunner have more torque yes, but you will have a cooling issue for sure, efficency not that good (65% mesured) , you will have a rpm drop (about 20-30%), this on the small jetdrive i have built for testing using a kmb28 and a outrunner
- jetdrive are more efficent thrust wise/power when smaller, but at some point you will be missing top speed
- you need a least 30km/h to fun and with a decent size board may be 50-60kg of thrust
- two jetdrives:
because you split power by two (esc wires motors…) more thrust/power on 52jet or 58jet rather than one 64jet
it has be done and this step work, but you will not go at 50km/h ( is it very important?)
-one drive:
we find motor, but esc??? really expensive, keeping blowing, espacially cap because on high voltage high amp on start
10000W 50v : 200a… a motor rated for 300A can pull maybe 450A on start (depending on brand)
if i built a jetdrive, it will cost me some money so i will do what i know that will work aiming for 30-35km/h
2 X JET58 , 56104 480KV, 12S, heifi 300a
- battery:
i know the 56104 480KV will pull this 128a at half rpm, half max voltage
JET 58: 330N with 6000W : 125A on 12S (simplified)
this is at max, start, planning speed might be less, closer to 5000W for 30km/h, i guess
so 2 packs , 125A on 2 or 3c : at least 42A 12S
you will use 70% on the pack, so to safe and have a decent play time : one pack will be 12S 40A
i think the most important: is not to under estimate KV:
you will have a rpm drop on load, rpm drop with voltage battery
if you spin to fast : 25000 rpm on 52jet you will have caviation, to low: no top speed
esc more happy with 100%, rather than 75% tps apparently
### Author: ![SoEFoil](https://foil.zone/user_avatar/foil.zone/soefoil/32/55_2.png) [@SoEFoil](https://foil.zone/u/SoEFoil)
#### Post date: [July 15, 2018, 12:19pm UTC](https://foil.zone/t/25-kw-electric-jetsurf/2143/6 "2018-07-15T12:19:48Z")
</div>
See also [http://www.efoil.builders/t/from-rc-toys-to-esurf-jet-on-a-tiny-pond/2156/4?u=soefoil](http://www.efoil.builders/t/from-rc-toys-to-esurf-jet-on-a-tiny-pond/2156/4?u=soefoil)
Mark is using two 53mm jet propellers that he sells 230 GBP each. FAr bellow the 25KW of this post.
Other candidate, the Graupner 49mm jet unit:
 ![2347_Jet_Antrieb5_11](https://foil.zone/uploads/default/original/2X/9/9730e56bdcfb94100cbdb594c9fe1c6c77a171a5.jpg)
The Graupner jet propulsion unit model 5 ref 2347 slightly less powerfull than the MHZ (but much cheaper too) with a 49mm impeller sold 150£ (GBP) =167€ from UK
### Author: ![DavidC](https://foil.zone/letter_avatar_proxy/v4/letter/d/a183cd/32.png) [@DavidC](https://foil.zone/u/DavidC)
#### Post date: [July 16, 2018, 1:31am UTC](https://foil.zone/t/25-kw-electric-jetsurf/2143/7 "2018-07-16T01:31:46Z")
</div>
> **[Water jet by joepvdw](https://www.thingiverse.com/thing:2217927)**
> 20mm water jet drive.
> Parts used:
> \-M3 screws for fixing the parts together.
> \-3mm shaft
> \-10mm bearing
> https://www.youtube.com/watch?v=gEJOSpgrLcU
> Nozzle: https://www.thingiverse.com/thing:2512106
### Author: ![MauiMan](https://foil.zone/letter_avatar_proxy/v4/letter/m/59ef9b/32.png) [@MauiMan](https://foil.zone/u/MauiMan)
#### Post date: [March 5, 2019, 12:23am UTC](https://foil.zone/t/25-kw-electric-jetsurf/2143/8 "2019-03-05T00:23:07Z")
</div>
I actually have a Jetsurf and to be honest, foiling only requires a fraction of that trust needed. On my jetsurf, I usually don’t go full speed neither cause you need really flat water( [https://youtu.be/RfOcHL9v-8Y](https://youtu.be/RfOcHL9v-8Y) ) My jetdrive on my jetsurf is about 80mm. I will take some photos later and post back. I have been building my jetdrive based on a combo of MHZ, @pacificmeister and @vefoil. I did an initial test last week.
Build and Testing
> **[Flying Fish Jet Drive Build](https://foil.zone/t/perfectwaves-flying-fish-jet-drive-build/3861)**
> Hi All Just wanted to share some fun videos from my jetdrive testing. It has been alot of trial and error. This prototype carbon/kevlar board was shaped by my friend at http://perfectwave.com maybe he can shape you one too. Here is the video of...
#### Post date: [March 5, 2019, 2:15am UTC](https://foil.zone/t/25-kw-electric-jetsurf/2143/9 "2019-03-05T02:15:01Z")
</div>
I stayed up a few nights and re-designed the jetdrive in the video.
### Author: ![Sliman\_O](https://foil.zone/user_avatar/foil.zone/sliman_o/32/10509_2.png) [@Sliman\_O](https://foil.zone/u/Sliman_O)
#### Post date: [October 6, 2019, 11:38am UTC](https://foil.zone/t/25-kw-electric-jetsurf/2143/10 "2019-10-06T11:38:51Z")
</div>
Did anyone of you guys saw this build ? This man has some serious craftsmanship. Video in three parts :
Also, he is pulling no less than 450N with a double motor geared drive 🙂
