I did not finish to built my 18650 pack yet with 12s16p of 30q , what i was running lipo last year , about 50h , i know that lipo are more rating discharge (min 10c), at first i was running my pack 15-20min and staid above 3.78v , at the end with skills and let then cooling a bit i was able to get Foil to 3,3v
As the graph of 18650 , they have lower C discharge more IR and more voltage sag , but they don’ t get on fire like my lipo did …
Running the mj1 at 1,5-2c is good above you loose a lot apparently and heat doesn’t help at all
It is possible to run inrunner wet , i had water in my pod almost all the Time… I just got the rear bearing rusted to the shaft and add a hard time to take it off but i guess just using corrosion X and flush it , it will ok for the season
