Belt Foil Assist – Will this enclosure fit a 13S2P battery and VESC?
Hello everyone,
I am building a DIY belt foil assist with a 13S2P battery and a Flipsky 75100 Pro V2 VESC, which I intend to mount on a heatsink against the enclosure wall.
I have found a waterproof enclosure with the following dimensions:
  • External: 210 × 160 × 100 mm
  • Internal: 192 × 142 × 88 mm
Do you think everything will fit inside, including the BMS, wiring and connectors? Or should I look for a larger enclosure? If so, what would be the optimal dimensions?
Thanks!
