For the last plate - box seal, I made my own seal from a 2 part silicon mix.
I made a 3D model and printed this to make the mold for this seal.
WOW very cool! will give it a try if i can find the right silicon mix. Thanks!
Hi Ben, Do you have the stl file for your mast gasket?
I do, but its custom for the base of my Tub, and the way my wires are run in the mast. - not sure how much use this will be to you.
