@sat_be I was afraid someone would say something like that. Makes sense though, thanks for the heads up! It sounds like even building a battery pack will cost about $700-900. Sound about right? Makes buying the pre-mades tempting.
[quote=“sat_be, post:31, topic:15470”].
Samsung 40T 21700 and Molicel P42A 21700 are also good cells and less spot welding.
[/quote]
I assume the bigger mAh means less batteries? That would be helpful, another good tip.
They’re different Molicel batteries, but @deeproot mentions here that the compromise is more on speed than run time. But that’ll obviously depend on rider, board, etc. In any case, thanks @sat_be for the info. I’ll check prices on both Samsungs and the Molicels. Gotta try to keep this as cheap as I can.
Go with the Molicel P26A Cells. I ordered from here: Molicel P26A 18650 2600mAh 35A Battery
Fast ship in USA, they are $3.90/cell now. My battery is 14s12p - 168 cells. I get about 1hr of runtime. My Samsung 30q battery performs exactly the same as my Molicel battery. I have over 50 rides on each battery now and see no difference other than the cost!
Tips:
Don’t skimp on the batter size. You want a long ride time.
No need for a water pump, water pressure from moving forward will push water up the mast to cool the vesc. I started with a pump but then removed it because it was not needed.
Flipsky 65161 - 120KV, Fliteboard Propellor, Maytech MTSKR1905WF, Flipsky 200A VESC (Not a single issue, ever, rock solid!)
Don’t use the Flipsky prop. Use this one: Flite Propeller | Fliteboard™ USA only $45. (Had to drill out on drill press with 12mm drill bit).
See my post to look at my hatch. I originally has hinges and cam latches. Water ALWAYS got it. My new method is a piece of acrylic and screws. I epoxied in 18 T-Nuts (under the silicone gasket) and screw the hatch down. It takes longer to setup the board but well worth it. Now it’s always bone dry!
The one thing I would change if I make another board would be the length. I would shorten the front of the board by about 10-12" just to make it smaller.
Or it could cost whatever the price of your house is when it burns down. Newbies shouldn’t start out with 200 cells in series / parallel. Learn with a much smaller battery or it could get painful physically and financially.
Lithium fires are pretty crazy to manage… Potentially impossible to manage if you are sleeping and it’s on fire in the garage.
The Molicel P42A are even cheaper per per capacity than the P26A. 4Ah vs 2.6Ah (14.4 vs 9.36Wh, 3.9$ vs 5$. 8 to 10P with 12-14S should be big enough. A 14S10P battery with P42A has a nominal capacity of 2.016 KWh. I run one with 96 cels (12S8P, 1380Wh) which gives me 40-50min riding time, dpending on the wing and average speed.
I hear you, makes perfect sense. And who knows, I might still follow you on Turnigy and see how it goes, for that same reason (time). We’ll see which way the wind blows. In any case, keep me posted on your progress!
@uberfoil What I hate to say is that you’re probably right, and this has crossed my mind more than once. I don’t have any other reason to build a battery, that I can think of. This is the first time in my life the idea has occurred. You think I’d be safer building a bunch of smaller batteries and then connecting in series for my first build? Or should I get another hobby that requires smaller batteries?
This is also helpful, and I know you mentioned that less spot welding. It’s good to know I have other options that will keep the cost down. I guess I’ll shop the options and see what makes sense.
50 min. sounds good. You happen to know what average speed gets you 50 min? Or what your max speed typically is?
I just keep hearing that the Flipsky prop is garbage. I have never actually used Flipsky prop. I have only used the Fliteboard prop and it’s excellent. Smooth and silent… and only $45. It works very well with the Flipsky 65161 - 120KV. My max speed is around 20mph at 80% throttle. I have never gone over 80% throttle. At 20mph+ over choppy water things get a little scary. I hit a big fish or something at 20mph and the board launched me 15 feet into the air, the foil sliced my leg open, had to apply a turnicate (zip tie) call 911 and get stitched up on the dock, lost lot’s of blood. So speed runs don’t end well. My average cruising speed is around 12-13mph. This is the butter zone and I have the most fun at this (safe) speed.
I was suggesting you cut your teeth on a small battery (for something else…) before jumping right into a massive efoil battery. Don’t try and connect a bunch of small batteries for an efoil. Well, I did read about a guy on here who uses drill batteries connected in series…
Anyway, it’s dangerous for a “total newbie” to connect up 196 cells for a first try. Smells like fire to me, unless you have some experience building batteries.
That was with max 33km/h and average 23km/h, so slow. Here is a metr log from another session that last 38min with an average speed of 26km/h Apr 11, 2022 - metr.at | o79Vf
https://youtu.be/S_GW5gZ88s8 Thanks for asking Emenel! My oldest son (19) recorded this yesterday (in Michigan, USA). I need to work on the fuselage placement as the main wing seems to be a bit far forward. I moved it back an inch and had really good results with a reduction in porpising. Water was extremely cold and my muscles refused to let me stay in the water any longer (put in the docks with wetsuit in AM, but later in the day I couldn’t get my wetsuit back on due to being wet and I am fat now).
Also your Gong equipment looks fantastic! I will definitely go with the Allvator v2 for my upcoming winter build in 6 months from now. I saved a ton of money by printing my own main fin, and using Crazyfoil for everything I could up to this point, so hope to learn a bunch more this summer with tweaking what I have. Overall, a very successful project so far.
@tritodd It’s alive! Haha, I love it man, looks fun. Were you able to stand up and fly a little bit? I agree with you, looks like a very successful build, especially for a first try. Need to see more videos from Michigan soon, hopefully the water will warm up a little.
P.S. wet suits are notoriously hard to get on, no shame!
Hi everyone, got another package today—120 Molicel batteries, 42A 21700. I know how expensive batteries are now. Sooooo there’s that. Fish tape is also here, waiting on nickel strips. Next step is figuring out the battery build. Off to YouTube. Once I start that I think I’ll post a thread in builds.
Shoot me any immediate battery advice or links, if you’ve got 'em. I was reading somewhere about cell-level fuses instead of just one for the whole battery. Particularly interested in exploring that if anyone has done it.
Hey, also in Canada, Victoria, where are you located? We d love to connect with people doing projects with thrusters, I’m going to convert an 18’ aluminum boat with a few soon.
