# Build from England - 80100 windsurf conversion
**URL:** https://foil.zone/t/build-from-england-80100-windsurf-conversion/4591
**Category:** Builds
**Created:** [May 29, 2019, 11:41am UTC](https://foil.zone/t/build-from-england-80100-windsurf-conversion/4591 "2019-05-29T11:41:18Z")
**Showing post:** 30
#### Post date: [June 20, 2019, 2:53pm UTC](https://foil.zone/t/build-from-england-80100-windsurf-conversion/4591/30 "2019-06-20T14:53:24Z")
@PowerGlider, is that the type of internal mirror surface requirement you had in mind when creating this thread (point 8) ?
> [@Optimize 63100 outrunner motor for wet cooling and direct drive](https://foil.zone/t/optimize-63100-outrunner-motor-for-wet-cooling-and-direct-drive/4627/1):
> 1. Streamlining the inside of the rotor, glueing of magnets, protection against corrosion and abrasion.
> **[Optimize 63100 outrunner motor for wet cooling and direct drive](https://foil.zone/t/optimize-63100-outrunner-motor-for-wet-cooling-and-direct-drive/4627)**
> Lets start a new thread, to optimize a new to be specified motor based on the existing Compared to the 6384PG we gain some wealthy stator length, it grows from 56 to 66mm, so the torque and power of the electro and magnetic system grow by 17.8%....
_[View the full topic](https://foil.zone/t/build-from-england-80100-windsurf-conversion/4591)._
