# Build from England - 80100 windsurf conversion
**URL:** https://foil.zone/t/build-from-england-80100-windsurf-conversion/4591
**Category:** Builds
**Created:** [May 29, 2019, 11:41am UTC](https://foil.zone/t/build-from-england-80100-windsurf-conversion/4591 "2019-05-29T11:41:18Z")
**Showing post:** 32
### Author: ![PowerGlider](https://foil.zone/user_avatar/foil.zone/powerglider/32/3670_2.png) [@PowerGlider](https://foil.zone/u/PowerGlider)
#### Post date: [June 25, 2019, 7:29pm UTC](https://foil.zone/t/build-from-england-80100-windsurf-conversion/4591/32 "2019-06-25T19:29:53Z")
Very nice plastic work! I made my coating much much thinner, around 0.1mm i guess. I hope it is conductive enough for the heat. The original thread about epoxying you find here:
> **[Direct drive outrunner with direct water cooling](https://foil.zone/t/direct-drive-outrunner-with-direct-water-cooling/570/4)**
> To make it clear: This is definitely unwanted. By such an application of plastic around the complete winding package, the thermal resistance is only worsened and can be worse in water than without anything in air. Also this is formulated very...
_[View the full topic](https://foil.zone/t/build-from-england-80100-windsurf-conversion/4591)._
