Oke thanks for the help I hope it wil work out!
Im in the process of casting mine. using the lost shell method - Used a zero infill PLA print. Ill pack this in wet fine sand, Add a spidget. and pour. might as well try. plenty of old alu knocking about. worth a shot i guess.
If you want can you show us the results? Would be interesting to see how it works out
My front clamp broke. Now I use this. Ugly as hell, but it does the job:D
I’m going to put some moldable epoxy around it for better streamline.
Oke that does not look so nice😅 I made a stainless steel insert a while ago. It works great but is a pain to bend exactly right.
Very smart and the way to do it , no trouble with Sls printed part ( even fine)
But that propeller
De FR mastclamp on my mini testing mast. Realy happy with the looks and super strong!
Thanks for the tip @Jezza
Did you make it (little adaptor) from Delrin/Acetal?
which prop are you using is that the flisky motor?
Thats the Solas prop. It needs to be modified a bit to fit
Is it a good prop for the flispyk motor?
It’s average. It worked as well as my 3D printed prop.
Made it from g10 on my cnc mill. Realy strong and good fit.
I have to test it but it was easy to fit to this motor. I also will test with a few aluminium props from china.
Do you really mean the black part at the rear of the motor ? Normally, G10 isn’t black…
Yes I made it from 4 plates. 3x 3mm and 1x 1.5mm tickness. You can buy g10 in every color that you want.
