# CNC machined Electric Hydrofoil
**URL:** https://foil.zone/t/cnc-machined-electric-hydrofoil/2237
**Category:** Builds
**Created:** [July 25, 2018, 8:13am UTC](https://foil.zone/t/cnc-machined-electric-hydrofoil/2237 "2018-07-25T08:13:02Z")
**Showing post:** 24
### Author: ![tylerclark](https://foil.zone/user_avatar/foil.zone/tylerclark/32/3_2.png) [@tylerclark](https://foil.zone/u/tylerclark)
#### Post date: [May 31, 2019, 8:54pm UTC](https://foil.zone/t/cnc-machined-electric-hydrofoil/2237/24 "2019-05-31T20:54:02Z")
Yes.
> **[Build from Moscow!](https://foil.zone/t/build-from-moscow/3970)**
> Hi!I apologize for my English,I write through the online translator.After studying your experience, my friend and I also decided to join you and start our project!Engine 56114, gearbox from the starter Lada Niva, the idea of ArtemkaMax.Gear shaft...
> **[MaB 1st attempt](https://foil.zone/t/mab-1st-attempt/1720/38)**
> After all this destruction… It will reborn from its dust!! New joint and double bearing/seals is arriving!
> **[666foil build in France](https://foil.zone/t/666foil-build-in-france/2633)**
> Hi, After an unfortunate first attempt, the second version finally sees the day. The configuration is traditional and complies with the recommendations of @pacificmeister Some pieces were machined in cnc and the others in Pla. The sealmount...
> **[Michion's Build](https://foil.zone/t/michions-build/2625/7)**
> I got my setup in the water today to test the seals. All 100% watertight. I couldn’t get them to leak 😁 Maybe during a crash they might still? Waiting on one more part to arrive before final assembly. Exciting! almost there! These things...
> **[New foil builder in Southern Sweden](https://foil.zone/t/new-foil-builder-in-southern-sweden/2235/23)**
> Engine to gearbox adapter finished, is a modified Pacificmeister design in alu.
_[View the full topic](https://foil.zone/t/cnc-machined-electric-hydrofoil/2237)._
