# Cutting open commercial batteries! (Lift, Onean, Flite, etc.)
**URL:** https://foil.zone/t/cutting-open-commercial-batteries-lift-onean-flite-etc/10490
**Created:** [October 27, 2020, 8:31pm UTC](https://foil.zone/t/cutting-open-commercial-batteries-lift-onean-flite-etc/10490 "2020-10-27T20:31:20Z")
**Showing post:** 69
#### Post date: [November 4, 2020, 12:09am UTC](https://foil.zone/t/cutting-open-commercial-batteries-lift-onean-flite-etc/10490/69 "2020-11-04T00:09:49Z")
> [@foilmore](#):
> is an off the shelf part or is it a proprietary Lithos creation?
This has been a hunt from day one ! Not much luck so far. Probably custom. Do you see any manufacturer symbol or logo inside the case ?
 ![LIFT Waterproof connector 02](https://foil.zone/uploads/default/original/3X/d/c/dc593b8188bb268a6d1b878d4a8a2e4fa83c67fa.jpeg)
The male and female metal connectors are manufactured by Odu, a German company.
> [@The Lift eFoil thread - info for the DIYer](https://foil.zone/t/the-lift-e1-efoil-thread-info-for-the-diyer/2024/82):
> In a [SupMike link](https://efoil.builders/t/mikes-inflatable-fanatic-build/6829/68?u=soefoil), found some connectors used by LIFT [from the German manufacturer ODU](https://www.odu-connectors.com/products/electrical-contacts/odu-lamtac/?tx_typoscriptrendering%5Bcontext%5D=%7B%22record%22%3A%22pages_102%22%2C%22path%22%3A%22tt_content.list.20.oduapplications_applicationlist%22%7D&tx_oduapplications_applicationlist%5Bapp%5D=1289&tx_oduapplications_applicationlist%5Baction%5D=view&tx_oduapplications_applicationlist%5Bcontroller%5D=ApplicationList&cHash=4273fb7f8f69da340f15b1783cbce7c8): Electrical Surfboard Hydrofoil The Hydrofoil electric surfboard from MHL Custom/Lift Foils requires a connection that is highly current-carrying. At a top speed of up to 40 km/h, it must also be vibration- and shock-resistant. Furthermore a corrosion-resistant connector is required which prevent the ingress of water. With a current carrying capacity of up to 2,400 A the ODU LAMTAC® is the perfect solution…
_[View the full topic](https://foil.zone/t/cutting-open-commercial-batteries-lift-onean-flite-etc/10490)._
