# Daniels (un)geared inflatable (slowly built)
**URL:** https://foil.zone/t/daniels-un-geared-inflatable-slowly-built/8069
**Category:** Builds
**Created:** [June 2, 2020, 9:40pm UTC](https://foil.zone/t/daniels-un-geared-inflatable-slowly-built/8069 "2020-06-02T21:40:42Z")
**Showing post:** 45
### Author: ![sat\_be](https://foil.zone/user_avatar/foil.zone/sat_be/32/35523_2.png) [@sat\_be](https://foil.zone/u/sat_be)
#### Post date: [July 10, 2020, 1:20pm UTC](https://foil.zone/t/daniels-un-geared-inflatable-slowly-built/8069/45 "2020-07-10T13:20:25Z")
**Update:**
The mast clamp didn’t last, I fell on the pod, the cable tie broke and then the printed mast clamp was the next weak link:
 ![IMG_8502](https://efoil.builders/uploads/default/original/2X/b/bd98873a522db70cde69736fc12716272a12fdf6.jpeg) ![IMG_8518](https://efoil.builders/uploads/default/original/2X/c/c25e7267716196418a8ed602af2c366f3c92d865.jpeg)
The duct broke as well, it was the old one from ASA-X without carbon reinforcement.
New mast clamp with 4 x M6 stainless threaded rods:
 ![image](https://efoil.builders/uploads/default/original/2X/c/c0256106bb1dcf7ba93c33d467dc1de9af82b4b7.jpeg)
 ![IMG_8539](https://efoil.builders/uploads/default/original/2X/e/e82f91dc6a4da764d3370a17fb90635e9580d2f6.jpeg) ![IMG_8541](https://efoil.builders/uploads/default/original/2X/3/3d4dd9fcc71ed3899bbd8272af43aa6a0793fe32.jpeg)
 ![IMG_8542](https://efoil.builders/uploads/default/original/2X/1/119181b5ceefa234c63f831d1113f130f9ee564f.jpeg) ![IMG_8543](https://efoil.builders/uploads/default/original/2X/a/a23bf3ea316542acc325d3b4ea22c950a167a17d.jpeg)
The white material is POM, so no 3d printed parts under load!
 ![IMG_8548](https://efoil.builders/uploads/default/original/2X/a/a3bbf42c20b8cbbcaa6660ce81b76103e1933b11.jpeg) ![IMG_8550](https://efoil.builders/uploads/default/original/2X/f/f9497977e4e32b3e80478fc0b01977055905ab0f.jpeg)
 ![IMG_8551](https://efoil.builders/uploads/default/original/2X/f/f42b58d41fa01a9f0b03d4faa98bbf4ab3a27463.jpeg) ![IMG_8552](https://efoil.builders/uploads/default/original/2X/8/88c5fe260de4856635eccbe08cffd94e25aaaa47.jpeg)
Seal with O-rings and POM plate that is fixed with screws.
 ![IMG_8553](https://efoil.builders/uploads/default/original/2X/4/47439ea1086d625f3a48f26507ddc55f5a92928a.jpeg) ![IMG_8559](https://efoil.builders/uploads/default/original/2X/f/fc78ff901fdd3d3ea6d00beedfcea017e16e78d4.jpeg)
3d printed enclosure can be snapped in and fixed with screw cap (copied @SUP-MIKE’s idea)
Thanks as well to @superlefax and @Toto44 from the german speaking group for their support.
 ![IMG_8565](https://efoil.builders/uploads/default/original/2X/8/825147aeee0f6cdc5298533bbf3032e912cb15ac.jpeg) ![IMG_8568](https://efoil.builders/uploads/default/original/2X/0/0c2b414bb7d946d62ec75ff68bea10df1ec5b366.jpeg) ![IMG_8545](https://efoil.builders/uploads/default/original/2X/3/31d6a67395c70ba8f598129702165ae4d83c4a6f.jpeg)
 ![IMG_8566](https://efoil.builders/uploads/default/original/2X/d/df5aecc3842b3da6febee9f6c4a9ab8efbdb932d.jpeg)
_[View the full topic](https://foil.zone/t/daniels-un-geared-inflatable-slowly-built/8069)._
