# DIY mast & wing sheap
**URL:** https://foil.zone/t/diy-mast-wing-sheap/605
**Category:** Foils & Boards
**Created:** [November 9, 2017, 3:34pm UTC](https://foil.zone/t/diy-mast-wing-sheap/605 "2017-11-09T15:34:31Z")
**Showing post:** 91
### Author: ![sat\_be](https://foil.zone/user_avatar/foil.zone/sat_be/32/35523_2.png) [@sat\_be](https://foil.zone/u/sat_be)
#### Post date: [April 5, 2026, 2:14pm UTC](https://foil.zone/t/diy-mast-wing-sheap/605/91 "2026-04-05T14:14:20Z")
See here how I built my mast, I still use it. It could be more stable but it is ok, put in as much fiber as you can fit in.
> [@Daniel's 2nd build](https://foil.zone/t/daniels-2nd-build/19956/2):
> Mast: The mast was built the same way as the wings. The mold is slightly more complicated as it consists of more than two parts. Design is from @visor360. Glued the pieces and aligned them to be straight/90° respectively Reinforced it with wood and glassed it over on the outside Built an insert from forged carbon to hold the FR motor. The insert was built with a 2 part mold, filled with epoxy and cfk flakes pressed together. Pin holes to fix the motor w…
_[View the full topic](https://foil.zone/t/diy-mast-wing-sheap/605)._
