Here’s my take on a waist-assist build, using Duotone equipment to keep things as simple as possible.
It’s working really well—I can flat-water start an 830 foil with ease. Each battery pack is under 100 Wh, and I’ve already flown four times with two sets of packs.
A few photos below showing the setup, battery connections and how it all fits together.
I used a Flipsky 75100 Pro V2.0 VESC. I cut a hole in the case and bolted the VESC directly through it, then used silicone to seal the aluminium VESC housing to the plastic Camden Boss case.
What batteries are you using? are they 12S packs? I’m afraid to travel with batteries unless they have a UN 38.3 stamp. But it sounds like you’ve had no issues with air travel
@Jezza - how are you liking that waistband without any additional support to your shoulders? Would you by chance be able to tell me the hole spacing/pattern dimensions?
To be fair I haven’t ridden it yet. This summer took a strange turn and time got away from me. I need to complete it though and see how I like it compared to unit on the board.
Nice build, this is exactly what I am trying to do.
I am doing a waist assist with a Flipsky 75200 Pro V2.0 in 12S, and I would like to mount the ESC through the case wall like you did. One thing I can’t figure out: how do you actually hold the VESC in place, since it has no mounting lugs? Is the silicone doing the work? And which silicone did you use?
My other concern is the screw holes around the fins, which end up outside the box. Do you know if they are blind or if they go through into the ESC? Did you seal them?
Does the system cool well in practice? Do you have an idea of the temperatures you reach?
