The price is great but I would be worried about the performance! Can it handle the amps we pull on an efoil (battery specs but also how they are connected)? Trying to save money on a battery pack can be risky/dangerous if it means buying products that will most likely underperform and/or are not genuine.
Did you have a chance to test the pack to see capacity and discharge rate meets the specs?
I not had time to do full capacity tests etc as i started to make a water proof box for the batteries.
I am coming to the order to make my 12s12p Sony VTC6 3000 mAh pack, and I would have liked your advice for the nickel strip section to order from Nkonā¦
thank you for your advice
Hey Guys, Just wanted to share a battery prices that Iāve gotten recently from Alibaba - they accepting Paypal (small fee) or Alibaba Trade Assurance - Iāve had no trouble with either.
For 48V 40Ah lithium battery with portable handle:
Battery cells : Imported LG battery cell
Charge current: 10A
Continuous Discharge current: 80A
Peak discharge current: 120A
Dimension: 340 x 270 x 106mm
Weithg: around 10.5kg
Leadtime: 10 days
10A lithium charger.
Shipping cost is by air and contain custom fee and tax taking around 12 - 15 days - Ireland.
I got talking to Ellina Xin via the chat function on Alibaba at the following Link: This product is no longer available.
Edit: I have not bought this - just passing on price and info. Iāve gone a down a different route with the Boston Swing Batteries (14 no. delivered to Ireland for $380 - 51.8V, 42Ah) as Iām using the MP70131 Motor and want to attempt to build-ish my battery (Its all part of it ā¦right??) & keep cost as low as possible plus I have the fear that I may need the extra OOMPF as Iām 85kg without adding anything else and I can add on modules for the battery if needs be. I have however asked if they will hold prices in case my mad notion collapses and they have agreed for 3 months!
its sell one by one ?Did we need to solder the flat cells? the box is after finish assemblate ? price is good!
The LG battery Cells come in a nice completed box with charger and whatever type of connectors you want. the Boston Batteries come in packs of 8 - ready made to 42Ah - youād then need to piece those 12/13/14 packs together in a configuration that youād like
are 80A and 120A not too less? Other guys tell up to 180A
If your interested, chat to her - the BMS takes more than 120A Peak and 80 Continous - they just have it set to that but its customisable - very helpful if you want to drop her a message.
I did it. Hope she answered.
Yeah, she answered already and made me the same offer.
"If the 48V 40AH lithium battery is ok for you, below is the basic info:
Battery cells: LG imported battery cells
Charge current: 10A
Countinous discharge current: 80A (Can be customized)
Peak discharge current: 120A (Can be customized)
Dimension: 340270106mm ( White case)
Weithg: around 10.5kg"
Unfortenately I don`t know anything about the FR motor.
I know 16 poles , 70mm , ? kv?
120A peak discharge is too less, I think
Which preferences would you recommend for this motor?
Ya she will sort you out!
The FR drive is around 130Kv
Battery wise I would look for 200A peak and 100A constant. It will just mean the battery lasts longer.
Okay, thank you. I will tell her.
But when I buy it now, I only need it for testing and placing in the Board. Now the Winter is coming. Is it useful to buy it now? Or is the standby bad for the battery?
Make a mock-up of the batteries and buy the real ones when you need them. You might find something better down the line.
good idea, thanks. I have just got the sheet about the battery. Does it look good? I don`t have any experiance. 4-5 h is not very fast, but for the beginning�
they can set the peak at 100 and 180A in the bms
It is a good deal I wish they could nake it with less Z . 105mm is very tall box to fit in the board
Yes, you are right. But it is their smallest Box. I will put 2 Alu-String er in the bottom of eps of the Board. It is only 1,5 cm thickā¦
380$. For those Boston Swing cells are very good price. I am just worried if they are genuine and meet the septs. Dod you have a chance to cycle any of the cells to validate?
