Mytech 65162 Electric Motor — one of the most powerful and reliable in its class, fully waterproof (IP68), and ideal for high-performance light marine applications.
The battery has 10 cycles of use.
Included Configuration:
• Mytek 65162 Motor regular prop (brushless, water-cooled, 120 KV)
• FESC 75250 High-Performance Controller
• 12S Li-ion Battery with approx. 4 kWh capacity
• Smart BMS with real-time monitoring and intelligent management
Performance:
• Continuous power: ~5 kW (≈ 6.7 HP)
• Peak power: up to 8 kW
• Top speed on SUP: up to 30 km/h
• System voltage: 44 – 50 V (12S)
Outstanding Range:
The 4 kWh battery is exceptionally large for this type of setup — it provides an incredibly long range, even when maintaining high cruising speeds throughout the trip.
Perfect for those who want to cover long distances without worrying about recharging.
Possible Applications:
• Mounting on a SUP (stand up paddle) or a tow buggy for extreme performance
• Compatible with inflatable kayaks
• Can be adapted for rigid kayaks or canoes
• Also ideal for electric tenders or experimental marine projects
Only 600€+ shipp
