# First build - Full Carbon efoil
**URL:** https://foil.zone/t/first-build-full-carbon-efoil/15918
**Category:** Builds
**Created:** [June 12, 2022, 3:47am UTC](https://foil.zone/t/first-build-full-carbon-efoil/15918 "2022-06-12T03:47:30Z")
**Showing post:** 63
### Author: ![Andrii](https://foil.zone/letter_avatar_proxy/v4/letter/a/77aa72/32.png) [@Andrii](https://foil.zone/u/Andrii)
#### Post date: [July 31, 2024, 2:25am UTC](https://foil.zone/t/first-build-full-carbon-efoil/15918/63 "2024-07-31T02:25:53Z")
Unfortunately, during the last session, I noticed the water inside the VX3 screen. It is my second VX3 remote, as the first one had the same problem but Flipsky agreed to replace it.
 ![IMG_0903](https://foil.zone/uploads/default/original/3X/b/c/bca87f126868b0a8098100072c503b9ebe9cc715.jpeg)
I took it apart and noticed a few cracks in the corner of the transparent plastic case for the TFT , which could have leaked from there.
 ![IMG_0908](https://foil.zone/uploads/default/original/3X/a/f/afab9cedd9a05519077d7d5fc8ef6fc4f03e9e08.jpeg)
 ![IMG_0906](https://foil.zone/uploads/default/original/3X/5/5/5500b0480f299ff95500f6deb6147da8bb51be4a.jpeg)
I removed the screen, filled the case with UV-stable epoxy, put it back to fully soak and applied a coat of RTV silicone around the case.
 ![IMG_0910](https://foil.zone/uploads/default/original/3X/d/5/d5523103d6f3305afa51c8da1a7c7193b2b5763c.jpeg)
 ![IMG_0912](https://foil.zone/uploads/default/original/3X/5/a/5ac7816d74596a1afbf8aa8b9f509b871229d791.jpeg)
 ![IMG_0927](https://foil.zone/uploads/default/original/3X/a/8/a871e57f195d7aacbf7ad54423952432f3070b49.jpeg)
_[View the full topic](https://foil.zone/t/first-build-full-carbon-efoil/15918)._
