# First ever build
**URL:** https://foil.zone/t/first-ever-build/21608
**Category:** efoils – Electric Hydrofoil Surfboards
**Created:** [August 24, 2024, 11:12pm UTC](https://foil.zone/t/first-ever-build/21608 "2024-08-24T23:12:21Z")
**Showing post:** 29
### Author: ![S\_Roger](https://foil.zone/letter_avatar_proxy/v4/letter/s/9de053/32.png) [@S\_Roger](https://foil.zone/u/S_Roger)
#### Post date: [August 28, 2024, 11:26pm UTC](https://foil.zone/t/first-ever-build/21608/29 "2024-08-28T23:26:46Z")
I have a Fliteboard adapter plate build. I don’t have my own build thread (yet), but I bookmarked a few of the other adapter plate builds:
> [@My simple bolt-on build on Maui (VESC, 6384, 10s2p)](https://foil.zone/t/my-simple-bolt-on-build-on-maui-vesc-6384-10s2p/17539/32):
> Update on eFoil build #1 (the one with the 6384 motor): I replaced the previous motor mount with a new one designed by @JonathanC (thank you!!) This motor mount is great because: It has a cable channel on the inside. No more hydrodynamic drag with some of the cable being exposed. I had to modify my motor a little bit with a Dremel so the cables leave the motor towards the rear. It uses less material to print It’s attached to the mast with 2 screws and has been rock solid so far
[UK Efoil build V2](https://foil.zone/t/uk-efoil-build-v2/18204) (not really adapter plate, but similar)
> [@Build on a Weekend](https://foil.zone/t/build-on-a-weekend/18411):
> Hello everyone, I would first like to thank you all for this great community and the knowledge and help you provide. My plan was to have a functioning board for the summer as soon as possible after graduation. But as you know, I couldn’t wait until the exams were over because I was constantly looking at the parts, so I built it quickly over a long weekend. Even though many will now think that it is not a real DIY, I find the Fliteboards very beautiful. I got it for a very reasonable price, for…
There are also a few builds that have used metal boxes filled with corrosionX. This is one example:
> [@Myndset's 1st Build Log - Southern California](https://foil.zone/t/myndsets-1st-build-log-southern-california/18767):
> First - Thanks to all those that have come before and the huge amount of knowledge this community has put together to help inform builds like this. I seriously couldn’t have done this without hours and hours of reading through foilzone. I’m about two months into my build and am finally getting around to collating all of the information, photos, and things I’ve learned along the way. There is a lot to post and add notes to so this will likely take a few days to bring up to date and get all my th…
_[View the full topic](https://foil.zone/t/first-ever-build/21608)._
