Foil assist build list
I haven’t gotten to that yet. I know a few builds have used an MR60/MT60 connector for phase wires. The solution @sat_be uses in his thread is also a really nice one by user @hangloose. If you go to printables.com you can search for “hangloose” to find files for the parts.
@MDHD if you look at the thread above that @sat_be linked, he uses a nice low profile vesc that I remember now bookmarked some time ago. It might fit inside the lid of the R60 get you a few more mm to work with: M-Classic – Budget VESC® Motor Controller | DQ Drives
My design is inspired by @hangloose but uses smaller 5.5mm bullets. It works quit well so far and max current is higher than mr60/mt60. I can share the file if there is interest.
Yes, I am interested in the files, and tips on how to make it, thanks!
Her we go: https://www.printables.com/model/1895432-waterproof-3-x-55mm-bullet-connector
Hello there, that looks great! May I ask, what length is the cable you ordered? I see in the image the coil is stretchable to 1m, but what length is the straight part?
The measurements are a bit weird and I just took a punt on the “1 meter” version. I think it means it has a total additional stretch of 1 meter. The straight bits aren’t very long. But I used the existing cables for the motor and the little bit on the blue plug and the lengths added up pretty much perfect.
And more info on your project? Interested to see details of your battery. :ok_hand:
Still collecting all data, and I will make a full post on the build. So far I got the belt, which is an action cam waist mount, Flipsky 75100 Pro V2.0, Flipsky 6384, and I am in contact with a friend who builds batteries for a living, I gave him the specs of the project, and he told me to leave it up to him to make the best he can. He told me that we will be going for 13s2p, but without many details on the batteries themselves. I wanted to ask you one more thing. I saw that in your build you are using the m25 connectors for the phase cables. They are rated at 50A. Are they sufficient? Aren’t the start up spikes 80-90 amps?
Yep, definitely a bottleneck. I’m going to see how it goes and monitor it. I think if I was to use it like a foil it may melt. Others seem to have used them with no problems. In effect they’re a similar rating to an MR60 connector. Or at least that’s what I keep telling myself..
I wonder what connector would be best for such use.
MR 60 are just “rated” for 30A continous.
If these can do 50A continous, they will easily be good enough.
That is very clean! What glue do you use for the gaps you make for the heatsink, cable connector holes etc on the box?
Hi, I share the M25 connector URL in case someone needs it. It was not easy to find the curved one
https://es.aliexpress.com/item/1005008612682928.html?channel=twinner
