# Foil Drive Assist, DIY
**URL:** https://foil.zone/t/foil-drive-assist-diy/12927
**Created:** [June 21, 2021, 3:51am UTC](https://foil.zone/t/foil-drive-assist-diy/12927 "2021-06-21T03:51:30Z")
**Showing post:** 1528
### Author: ![rttn](https://foil.zone/letter_avatar_proxy/v4/letter/r/bcef8e/32.png) [@rttn](https://foil.zone/u/rttn)
#### Post date: [May 13, 2024, 2:30pm UTC](https://foil.zone/t/foil-drive-assist-diy/12927/1528 "2024-05-13T14:30:12Z")
> [@Swabian Efoil build](https://foil.zone/t/swabian-efoil-build/14556/35):
> Got finaly a new working version of the Folding Prop. I tried a lot of different things. Here is the final changelog: completly redesigned the blades to reduce mechanical weakpoints also finetuned the tolerances to reduce sanding to ~1 minute added a TPU 95A damping system raised the printing temerature of PETG to 250°C for better layer adhesion printed with 0.1 layers, 4mm walls and 40% cubic infill. No Support for the Blades with dual blowersystems after sanding everything i mount the blades…
_[View the full topic](https://foil.zone/t/foil-drive-assist-diy/12927)._
