# Foil Drive Assist, DIY
**URL:** https://foil.zone/t/foil-drive-assist-diy/12927
**Created:** [June 21, 2021, 3:51am UTC](https://foil.zone/t/foil-drive-assist-diy/12927 "2021-06-21T03:51:30Z")
**Showing post:** 360
### Author: ![sat\_be](https://foil.zone/user_avatar/foil.zone/sat_be/32/35523_2.png) [@sat\_be](https://foil.zone/u/sat_be)
#### Post date: [July 26, 2022, 7:48am UTC](https://foil.zone/t/foil-drive-assist-diy/12927/360 "2022-07-26T07:48:09Z")
You could put them in two rows. Think of just 2 out of the six rows (link below), but always the 2 next to each other in parallel. I used spacers from Ali.
> [@Daniels (un)geared inflatable (slowly built)](https://foil.zone/t/daniels-un-geared-inflatable-slowly-built/8069/56):
> Also built LiIon packs as the Lipos started to loose capacity. As it is hard to get cells at the moment, I chose Molicel P42A 21700, they were available. The battery is split into two 6S packs to fit the hatch. Max I could fit in was 6S8P. 0.2mm nickel strips It was a bit tricky to solder the 8AWG wires to the strips (between the cells) but I had to minimise the size to fit them through the hatch…
_[View the full topic](https://foil.zone/t/foil-drive-assist-diy/12927)._
