I know, another one. Here’s what’s different.
Some of you saw the watch screens in my Takuma thread. The app is called Foilborne, and the test builds are now open to anyone here.
It records a foil session on your Apple Watch, or on the iPhone alone, and works out what happened. When were you flying? What carried the board? How fast did you go? Where did you fall? Each discipline gets its own analysis. It’s a hobby project, with no subscription (see What it costs below), and in the beta everything is free.
Join the beta: Join the Foilborne beta - TestFlight - Apple
On the water
Pick the discipline, where you’re riding (flat water, waves or downwind) and your gear, then Start. On an Ultra, one press of the Action button starts it, which is the one control that works with wet hands.
While you ride, the pages show:
- your speed as large as the screen allows;
- whether you’re foiling, with your flights and time on foil;
- with a motor, the pack, power, amps and Wh/km live from the ESC.
A press of the Action button marks a moment, like a good wave, a fall or a jibe that worked. The mark shows on the map and the timeline afterwards.
On the iPhone afterwards
The session arrives on the phone by itself. You get the map, and a replay with the trail, wind angle, speed and heart rate at every moment. You can drag across the timeline to read any second.
The timeline’s strip shows when the board was flying and on what: pumping, gliding, sailing, surfing or the motor. Flights, tacks, jibes, carves and falls are marked where they happened.
Wing, kite and windfoil
Wing, kite and windfoil sessions get:
- Speed by wind angle, a polar of your typical and best speeds, with your best upwind and downwind VMG and the time each happened.
- Pump sets, carves with the g you pulled, and touches where the board or a tip hit the water.
Prone, surf and downwind
Every wave or swell ridden for 4 s or more is ranked by time, distance or top speed. Each session’s best is ranked against your previous sessions.
eFoil and foil assist
With a VESC and a Bluetooth module (a Flipsky BLE module or a VESC Express), the watch records the ESC alongside the GPS. Afterwards you get:
- Battery used, Wh/km on foil, and lift-offs.
- The take-off: the hump speed, lift-off speed, and the drag through the push.
- The motor: time in thrust, ventilating and off, with every ventilation caught (prop rpm against current).
- Energy by speed: Wh/km in 2 km/h bands, so you can see the speed your setup is cheapest at.
New in this build
- No watch needed. The iPhone records on its own, with the GPS and, on an eFoil, the ESC over Bluetooth. Lock it and put it in a pouch. Taking a phone on the water is your own call.
- The Lock Screen. Whichever device is recording, the session shows on the iPhone’s Lock Screen and in the Dynamic Island, with Mark and End.
- Falls are read properly. That covers falls from flight, including going in sideways, and falls off the board while still on the hull.
- Forgot to end a session? The watch asks after ten minutes dry and still, or once you’re driving. A session that ran into the drive home is trimmed back to the water, so the car never becomes your top speed.
Weather and tide
Each session carries the wind and the tide at the time. The tide page shows the height, the current and the next highs and lows for wherever you ride.
Everything else
- Every discipline: prone, SUP, wing, kite, parawing, pump and dock start, tow and wake, surf, eFoil and foil assist.
- Apple Health: every session is saved as a workout, with the route, heart rate and energy, and each flight as a segment.
- Your sessions stay on your phone. Nothing goes anywhere unless you send it. You can export all of them to one backup file.
- Units: km/h, knots or mph.
- Languages: English, French, German, Dutch, Japanese, Thai, Spanish, Italian and Brazilian Portuguese.
What it costs
No subscription, ever. Many trackers charge monthly even for the basics. Foilborne doesn’t.
- Recording is free in every discipline. Every session gets its track, speed, time and distance at no cost, whatever you ride.
- One discipline is free, fully analysed. You choose it yourself, once, and you get everything the app knows about it. That covers flights, the timeline, the discipline’s own analysis, effort and heart rate, the ranking, and the Apple Health workout. The choice is permanent, so pick the one you ride most.
- Other disciplines are a one-off purchase. Each is US$1.99, or all of them for US$9.99, now and as new ones are added. You own them for good, and Family Sharing shares them.
- Buying later unlocks your old sessions too. Every session is analysed again from its log, so nothing you’ve recorded is lost.
- Motor is the eFoil module. It also adds the ESC analysis to a foil assist in any discipline you have. Pump and dock start likewise adds the pump analysis to the pumped legs of any discipline.
- In the beta every module is free and nothing is charged. Beta purchases don’t carry over to the App Store version, but your free discipline does.
- No account and no sign-in. Purchases belong to your Apple Account.
Testers who turn on Help improve Foilborne and send me their sessions get thanked with App Store codes. Five sessions, each sent with a note, earn a code for any one module, and twenty earn a code for all of them. The codes carry over to the App Store version.
Android?
It’s being worked on. The analysis is the same code and is tested against the same sessions as the iPhone’s. The watch is the hard part. Android watches aren’t yet up to recording a whole session the way an Apple Watch is: GPS, motion and the ESC together for hours, with a button that works wet. So on Android the phone will do the recording, as the iPhone can now. There’s no date yet.
What you need
- An iPhone on iOS 26.
- If you use a watch, an Apple Watch on watchOS 26. The Ultra is best, for its Action button.
- For the motor’s data, a VESC with a Bluetooth module.
The tester guide covers setup, what to test, and how to send me a session when something looks wrong. It’s in English, French, German, Dutch, Japanese and Thai:
Why I want testers
The analysis gets better from real sessions. The fall detection in this build came from one tester’s sessions and my own attempts. If something is read wrong, like a fall it missed or a flight it invented, tell me which session and roughly when. The app can send me that session’s files, encrypted so only I can open them.
Questions here, or at foilborne.app@gmail.com.
