# FS: HGLTech / Flipsky Motor ESC Kit (Bay Area, California)
**URL:** https://foil.zone/t/fs-hgltech-flipsky-motor-esc-kit-bay-area-california/12907
**Category:** Buy & Sell
**Created:** [June 16, 2021, 7:50pm UTC](https://foil.zone/t/fs-hgltech-flipsky-motor-esc-kit-bay-area-california/12907 "2021-06-16T19:50:12Z")
**Posts on this page:** 8
**Page:** 1
<div class="post-metadata">
### Author: ![Hendo\_Rising](https://foil.zone/user_avatar/foil.zone/hendo_rising/32/18007_2.png) [@Hendo\_Rising](https://foil.zone/u/Hendo_Rising)
#### Post date: [June 16, 2021, 7:50pm UTC](https://foil.zone/t/fs-hgltech-flipsky-motor-esc-kit-bay-area-california/12907/1 "2021-06-16T19:50:13Z")
</div>
Selling my HGLTech motor kit for e-foils. I’m moving to Hawai’i so need to clear unfinished projects.
HGLTech Flipsky 65162 Motor
Walrus 300a water-cooled ESC
7 Inch prop
WH4 waterproof remote
New, still in box. Imported in March. Been in my room since.
 ![IMG_20210616_104424](https://foil.zone/uploads/default/original/3X/5/9/597eae8dee9e92c802485ed861da49c6f2eb28a6.jpeg) ![IMG_20210616_104403](https://foil.zone/uploads/default/original/3X/b/f/bfdee930af9c2c4d78b27679672528500420e57a.jpeg) ![IMG_20210616_104412](https://foil.zone/uploads/default/original/3X/8/7/8746f5fa8f246c93c1b7a68eb6776152dd7afa9a.jpeg) ![IMG_20210616_104418](https://foil.zone/uploads/default/original/3X/7/c/7c6cbd831b57fed8a07f72cf129ac9c6b64b1534.jpeg) ![IMG_20210616_104431](https://foil.zone/uploads/default/original/3X/2/7/27deabb4c585adff4b8938640320231a4be5627d.jpeg) ![IMG_20210616_104444](https://foil.zone/uploads/default/original/3X/d/7/d797024bdc021e143f26da7b6f95bbce92d0cf95.jpeg)
$700 obo. Prefer local pick up but will ship at buyers expense.
Link here: [https://firduo.com/products/electric-hydrofoil-kits-65162-motor-7inch-propeller-300a-esc-wh4-remote-controller?variant=32981039808589](https://firduo.com/products/electric-hydrofoil-kits-65162-motor-7inch-propeller-300a-esc-wh4-remote-controller?variant=32981039808589)
### Author: ![Dr4lex](https://foil.zone/letter_avatar_proxy/v4/letter/d/df788c/32.png) [@Dr4lex](https://foil.zone/u/Dr4lex)
#### Post date: [June 28, 2021, 12:14am UTC](https://foil.zone/t/fs-hgltech-flipsky-motor-esc-kit-bay-area-california/12907/2 "2021-06-28T00:14:18Z")
</div>
hey
ave you sold this?
#### Post date: [June 28, 2021, 2:14am UTC](https://foil.zone/t/fs-hgltech-flipsky-motor-esc-kit-bay-area-california/12907/3 "2021-06-28T02:14:30Z")
</div>
Nope Still Available.
### Author: ![Dynamik](https://foil.zone/user_avatar/foil.zone/dynamik/32/5952_2.png) [@Dynamik](https://foil.zone/u/Dynamik)
#### Post date: [June 28, 2021, 5:58am UTC](https://foil.zone/t/fs-hgltech-flipsky-motor-esc-kit-bay-area-california/12907/4 "2021-06-28T05:58:41Z")
</div>
The propeller is not suitable for e-foil, you can’t put a quality propeller on a splined shaft. Only a very low selling price would compensate for that.
### Author: ![Jezza](https://foil.zone/letter_avatar_proxy/v4/letter/j/dfb087/32.png) [@Jezza](https://foil.zone/u/Jezza)
#### Post date: [June 28, 2021, 9:54am UTC](https://foil.zone/t/fs-hgltech-flipsky-motor-esc-kit-bay-area-california/12907/5 "2021-06-28T09:54:58Z")
</div>
With a a hole drilled into the shaft for a pin the Fliteboard prop will fit fine (the splines have a 11mm diameter with is the same as the prop).
If you wanted to use the FR prop then all you need to do is drill a hole for a pin and then take off 5mm of the spline. This took me 10 minutes…
#### Post date: [July 1, 2021, 4:39pm UTC](https://foil.zone/t/fs-hgltech-flipsky-motor-esc-kit-bay-area-california/12907/6 "2021-07-01T16:39:56Z")
</div>
Price drop. $650 obo
#### Post date: [July 7, 2021, 5:39pm UTC](https://foil.zone/t/fs-hgltech-flipsky-motor-esc-kit-bay-area-california/12907/8 "2021-07-07T17:39:08Z")
</div>
This is not true. This prop works great with this motor. [Flipsky 100kv flier esc Holland build](https://foil.zone/t/flipsky-100kv-flier-esc-holland-build/6646)
#### Post date: [July 28, 2021, 5:47pm UTC](https://foil.zone/t/fs-hgltech-flipsky-motor-esc-kit-bay-area-california/12907/9 "2021-07-28T17:47:39Z")
</div>
SOLD on ebay. Thanks!
