FS: HGLTech / Flipsky Motor ESC Kit (Bay Area, California)
Selling my HGLTech motor kit for e-foils. I’m moving to Hawai’i so need to clear unfinished projects.
HGLTech Flipsky 65162 Motor
Walrus 300a water-cooled ESC
7 Inch prop
WH4 waterproof remote
New, still in box. Imported in March. Been in my room since.
$700 obo. Prefer local pick up but will ship at buyers expense.
Link here: https://firduo.com/products/electric-hydrofoil-kits-65162-motor-7inch-propeller-300a-esc-wh4-remote-controller?variant=32981039808589
hey
ave you sold this?
Nope Still Available.
The propeller is not suitable for e-foil, you can’t put a quality propeller on a splined shaft. Only a very low selling price would compensate for that.
With a a hole drilled into the shaft for a pin the Fliteboard prop will fit fine (the splines have a 11mm diameter with is the same as the prop).
If you wanted to use the FR prop then all you need to do is drill a hole for a pin and then take off 5mm of the spline. This took me 10 minutes…
Price drop. $650 obo
This is not true. This prop works great with this motor. Flipsky 100kv flier esc Holland build
SOLD on ebay. Thanks!
