Fair point on the volume. I’ll keep this one short.
Agreed, the joint is the hard part, and it’s where most of my last week went. Short answer for now: the semi socket. The fuselage’s nose, or a flat bar on a home build, drops into a pocket molded into a hub on top of the wing, with carbon cheeks either side. The cheeks take the twist and the side load, so the bolts only have to hold it down. The fit is set in the mold, 0.1 to 0.2 mm a side, rather than by sanding. The next thing I’m adding is bolting it from the wing side, up through solid laminate into the fuselage instead of into inserts, as a lot of production wings do.
The longer answer is that I’m not trying to pick one. In a parametric tool the joint is a dropdown and a few dimensions, so the variations are cheap. What’s useful is having options that fit what people already own. Right now that’s a flat mount, the semi socket, a full square socket for a bar and a round tube socket, plus a production-style mount pad on the stab. Next is a joint that mates with Gong’s V3 fuselage, so a molded wing bolts straight onto a fuselage that’s already common. That one waits on me buying a V3 and measuring it.
Whichever joint, the tool works out the loads in a hard carve (3 g by default) and checks the laminate against them:
- root bending and the carbon caps
- core shear
- how much carbon is left under each bolt head
- the fuselage in torsion
What it can’t tell me is play and fatigue over a season, and you’re right that that’s where the bigger foils struggle. That takes someone building one and riding it, which is the next step.
