# Has anyone successfully used the Flipsky FSESC 75200 with the FS65161 motor?
**URL:** https://foil.zone/t/has-anyone-successfully-used-the-flipsky-fsesc-75200-with-the-fs65161-motor/12052
**Category:** Propulsion System (Motor, Gears)
**Created:** [March 4, 2021, 10:11pm UTC](https://foil.zone/t/has-anyone-successfully-used-the-flipsky-fsesc-75200-with-the-fs65161-motor/12052 "2021-03-04T22:11:58Z")
**Showing post:** 137
### Author: ![osavcic](https://foil.zone/user_avatar/foil.zone/osavcic/32/24313_2.png) [@osavcic](https://foil.zone/u/osavcic)
#### Post date: [May 7, 2023, 8:02pm UTC](https://foil.zone/t/has-anyone-successfully-used-the-flipsky-fsesc-75200-with-the-fs65161-motor/12052/137 "2023-05-07T20:02:56Z")
Also felix remote is compact solution…
> [@Montenegro efoil WildBuild](https://foil.zone/t/montenegro-efoil-wildbuild/10864/71):
> Today I finally tested @Felixfoiler remote on the sea with new FS75200 and 120kv with choped 5inch prop on last 4.4 diy board. For testing purposes I didn’t put water cooling on esc so I could easily monitor temp and other parameters during ride on remote. At short break you can download and see data log on phone from sd card from reciever via wifi. Everything went perfect…
_[View the full topic](https://foil.zone/t/has-anyone-successfully-used-the-flipsky-fsesc-75200-with-the-fs65161-motor/12052)._
