OK, but do you have VESC data available ?
A link to show/buy them ?
Any more info? This is the first I have heard of this option.
Whats the total diameter?
That just looks like you reselling a bow thruster propā¦
something like this?
seems to be this one:
It is so cheap, canāt be good
3d printing is way cheaperā¦and yet the props work. Thereās no need to pay high prices for injection moulded parts like this.
Got an actual link?..
How good is he working?
Do you test theme?
Its the side power 31261. 125mm diameter and uses a prop pin. Some of the others donāt use a pin.
Itās good to have a much cheaper alternative prop for those that just want to get on the water and donāt want to wait!
They also make dedicated GRP sections for the props. These could very easily be used to make strong ducts for guys wanting protectionā¦
Well its not the above prop but same manufacturer, its customizedā¦it works really efficient for speeds up to 30km/h with 120kv motors and is a good alternative for the hardly available FR prop;-)
Customized how? Customized the price maybe⦠but the prop looks pretty standard to me!
different mold than the above oneā¦you can as well test the one above⦠will work as well, just not as perfect for the motors you use;-)
So is the hub modified to make it easier to mount? Can you please be a bit more specific?
Ouch. you guys sure are fast. Itās painful to see the unnecessary middle man cut away five minutes after heās shown the product.
Well this is a diy forum. !
Hi Ackermann,
is your 7inch prop based on the folding prop design from superlefax which he shared recently? Or some other prop wing shape? I am planning on printing the prop as well to gain some experience with a folding prop.
Does anyone have the line to line resistances for the 65162 120KV and 100KV Motors? I am not sure anymore what my maytech labeled motor actually is. Counting the windings may be difficult.
debeam
