# Holland board build
**URL:** https://foil.zone/t/holland-board-build/2458
**Category:** Builds
**Created:** [August 9, 2018, 7:39pm UTC](https://foil.zone/t/holland-board-build/2458 "2018-08-09T19:39:25Z")
**Showing post:** 18
### Author: ![Thijs](https://foil.zone/user_avatar/foil.zone/thijs/32/3712_2.png) [@Thijs](https://foil.zone/u/Thijs)
#### Post date: [September 2, 2018, 6:15am UTC](https://foil.zone/t/holland-board-build/2458/18 "2018-09-02T06:15:07Z")
Sounds good, my thought is just that you need some additional cable length somewhere in case you want to detach your mast from the board when transporting.(Or you could detach the cables from the esc every time you transport it.)
_[View the full topic](https://foil.zone/t/holland-board-build/2458)._
