# Lift f antenna broken off \[solved\]
**URL:** https://foil.zone/t/lift-f-antenna-broken-off-solved/19705
**Created:** [December 1, 2023, 4:45am UTC](https://foil.zone/t/lift-f-antenna-broken-off-solved/19705 "2023-12-01T04:45:51Z")
**Showing post:** 9
#### Post date: [December 3, 2023, 1:17pm UTC](https://foil.zone/t/lift-f-antenna-broken-off-solved/19705/9 "2023-12-03T13:17:13Z")
The solution: bring it back home like a power tool !
'[New Foil Assist: here is the "TakeOff" from Manta Foils](https://foil.zone/t/new-foil-assist-here-is-the-takeoff-from-manta-foils/19710)
> [@New Foil Assist: here is the "TakeOff" from Manta Foils](https://foil.zone/t/new-foil-assist-here-is-the-takeoff-from-manta-foils/19710):
> I thought this probably deserves its own post - a new under board foil assist from forum member @Mantafoils. Looks to be well thought out and designed at an amazing price point.
_[View the full topic](https://foil.zone/t/lift-f-antenna-broken-off-solved/19705)._
