Done! Sorry for the delay @hexakopter
Thanks a lot @tylerclark . Now the graphs are directly visible on this forum when posting a metr recording link in a single line.
To see what it looks like here the link from the beginning of the thread again. (Its not working when posting it in a sentence Jun 2, 2019 - metr.at | wz32k like in the first post)
But on a single line it looks like that.
I clearly need to upgrade to a VESC! haha. I never have any log data from my rides!!! Thinking about getting the Flipsky VESC since I use their ESC’s in my eks8’s and love them.
Is that metr.at Bluetooth dongle compatible with that Flipsky 200A FSEC?
And is metr compatible with the VESC-tool App?
Yes for vesc , probably as I recall the vesctool
But I am not sure your can run vesc tool on window pc and connect the vesc beside the usb cable
Better chance with android vesctool/metr.at
Omg, i mailed Dario yesterday, that it would be nice to have rpm data visualized…
And today, tadaa:
OK, its erpm, so you need to / 7
Edit: seems, like rpm visualized in Metr App will come soon.
Thats what i call perfect customer support
Thank you for adding this
Just a question. After all configuration, where the data are stored during your run?
Ah consumed from switch on and until switch VESC off is stored as well in the vesc ( at least in mine 75/300), at the end before turning off the vesc , I connect my phone and I can get this data
Ok thank you. so how do you do. you take your phone with you during the run? there is no way to store data in a SD, more than Ah like say @Alexandre?
Any hint on which VESC you used ? Your temperature at such High current is quite impressive !
It is a tuned prototype from nickw1881. I use a passive air/water cooler which sits on top of the box and is kept wet.
