Modified Hiorth-build from Sweden
Hi Riwi,
nice videos and pictures. I am curious about some data if you can:
How long is your board? Volume?
How much you weight?
what was your max speed? is any of the videos speed up?
If you could share also your system specs it would be great (Motor, esc, propeller )
Many thanks.
Regards,
Rui
How long is your board? Approx 165cm
Volume? Approx 80L
How much you weight? 75kg
what was your max speed? +18knots
is any of the videos speed up? Hell no!
If you could share also your system specs it would be great (Motor, esc, propeller ) Its in my bio. Its a hiorth build but I run a smaller prop, 20mm smaller dia.
Thanks for the infos Riwi,
i was checking your Instagram.
Great work.
I am still so long to try my build…but i will keep going forward.
