# Newbie DIY foil assist France
**URL:** https://foil.zone/t/newbie-diy-foil-assist-france/18779
**Created:** [August 2, 2023, 5:05am UTC](https://foil.zone/t/newbie-diy-foil-assist-france/18779 "2023-08-02T05:05:47Z")
**Showing post:** 19
### Author: ![lishine](https://foil.zone/user_avatar/foil.zone/lishine/32/29468_2.png) [@lishine](https://foil.zone/u/lishine)
#### Post date: [October 10, 2023, 10:15pm UTC](https://foil.zone/t/newbie-diy-foil-assist-france/18779/19 "2023-10-10T22:15:31Z")
Hey, maybe you did not see my question, I am asking about the BLHeli esc in the foil-assist topic.
Would you be able to answer it here (in order to not overfill the foil-assist topic)?
I am very interested to know if this esc is a viable alternative to Flycolor…
Thank you
> [@Foil Drive Assist, DIY](https://foil.zone/t/foil-drive-assist-diy/12927/949):
> So you disconnect the cable from the receiver side and connect to the programmer, or you have a T there ? It is actually two wires that active, right ? I only use plug and play ESC, very powerful and sensitive trigger Do you mean this Esc is PNP ? Sensitive trigger using this ESC ? And it cannot be tuned in the settings? The Acceleration setting cannot tune it? What are the impications of sensitive trigger? How do you isolate the box around the heatsink? weld motor wires at 45degrees W…
_[View the full topic](https://foil.zone/t/newbie-diy-foil-assist-france/18779)._
