# Power limit flipsky vesc 75200 and vx3 and 65161
**URL:** https://foil.zone/t/power-limit-flipsky-vesc-75200-and-vx3-and-65161/18484
**Category:** efoils – Electric Hydrofoil Surfboards
**Created:** [June 24, 2023, 7:52pm UTC](https://foil.zone/t/power-limit-flipsky-vesc-75200-and-vx3-and-65161/18484 "2023-06-24T19:52:17Z")
**Posts on this page:** 12
**Page:** 1
<div class="post-metadata">
### Author: ![windego](https://foil.zone/letter_avatar_proxy/v4/letter/w/ecccb3/32.png) [@windego](https://foil.zone/u/windego)
#### Post date: [June 24, 2023, 7:52pm UTC](https://foil.zone/t/power-limit-flipsky-vesc-75200-and-vx3-and-65161/18484/1 "2023-06-24T19:52:17Z")
</div>
Newbie here just going from knees to standing and find the throttle very sensitive at the beginning of session when the battery is fresh.
Is it best to limit power or current? I have it wide open right now at battery 200amps and 6000watt.
### Author: ![SoEFoil](https://foil.zone/user_avatar/foil.zone/soefoil/32/55_2.png) [@SoEFoil](https://foil.zone/u/SoEFoil)
#### Post date: [June 24, 2023, 10:49pm UTC](https://foil.zone/t/power-limit-flipsky-vesc-75200-and-vx3-and-65161/18484/2 "2023-06-24T22:49:03Z")
</div>
What is your remote brand ?
You could change the throttle curve so that the efoil is smoother during startup.
> [@Foil Assist with Flipsky 65111 for Axis Mast (and Flipsky 75100 ESC)](https://foil.zone/t/foil-assist-with-flipsky-65111-for-axis-mast-and-flipsky-75100-esc/17041/28):
> App Settings / VESC Remote / Throttle Curve: two parameters in efoil/surf mode (XX no reverse): 1- “Throttle expo” field allows to create a soft start (eg not to break a 3D printed prop during startup), the more negative the number the smoother the start [typ -20]. 2- “Throttle expo mode” accentuates the smoothing effect: Exponential \> Polynomial \> Natural. Everything is explained here for an Esk8 which has a (Throttle expo) brake feature not present for efoils: [[Adjust Throttle …](https://www.youtube.com/watch?v=HfjgwhYi8IE)
#### Post date: [June 25, 2023, 1:33pm UTC](https://foil.zone/t/power-limit-flipsky-vesc-75200-and-vx3-and-65161/18484/3 "2023-06-25T13:33:11Z")
</div>
Its a flipsky vx3. I’ll check out the link thanks.
#### Post date: [June 25, 2023, 2:02pm UTC](https://foil.zone/t/power-limit-flipsky-vesc-75200-and-vx3-and-65161/18484/4 "2023-06-25T14:02:29Z")
</div>
[![](https://img.youtube.com/vi/HfjgwhYi8IE/maxresdefault.jpg "Adjust Throttle Curve On Vesc Tool - DIY Electric Skateboard") ](https://www.youtube.com/watch?v=HfjgwhYi8IE)
found this too
### Author: ![Fillemupp](https://foil.zone/user_avatar/foil.zone/fillemupp/32/27518_2.png) [@Fillemupp](https://foil.zone/u/Fillemupp)
#### Post date: [June 25, 2023, 2:05pm UTC](https://foil.zone/t/power-limit-flipsky-vesc-75200-and-vx3-and-65161/18484/5 "2023-06-25T14:05:26Z")
</div>
I have a VX3 remote as well with FSESC75200 and 65161. I agree that the throttle is super sensitive and it has been a challenge to just control the speed. It has taken me some hours practicing to stand and foil…
Found out now that the button next to the power button toggles between three different speed modes L, M and H. Default is H (high). When switching to L (low) the full throttle gives much less power, so the throttle is easier to handle for a beginner. My 11 year old kid (31 kg) now managed to get up and stand on the board just within one session on the L setting. He can also get to foiling speed but balance is not there yet…
L is not power enough for me to get to foiling though, I can only plow around standing up. I need M, which is enough power for me (75 kg) to get up and foil around at 30 km/h.
Please note that this is on my rifle case board that is not at all optimized for good flow in the water. I have my VESC configured to regulate to speed and not to current. Not sure if that makes a difference regarding L, M and H though.
#### Post date: [June 25, 2023, 2:08pm UTC](https://foil.zone/t/power-limit-flipsky-vesc-75200-and-vx3-and-65161/18484/6 "2023-06-25T14:08:24Z")
</div>
Ok thankyou great info. Lots to try.
### Author: ![Foilguy](https://foil.zone/letter_avatar_proxy/v4/letter/f/7cd45c/32.png) [@Foilguy](https://foil.zone/u/Foilguy)
#### Post date: [June 25, 2023, 4:29pm UTC](https://foil.zone/t/power-limit-flipsky-vesc-75200-and-vx3-and-65161/18484/7 "2023-06-25T16:29:19Z")
</div>
@Fillemupp
I’ve searched for the how-to on this feature and know that I’ve seen it somewhere but can’t seem to find it again.
Can you post the button pressing steps to make this L,M,H happen
I assume the button you are referring to is the “Settings” button.
#### Post date: [June 25, 2023, 6:08pm UTC](https://foil.zone/t/power-limit-flipsky-vesc-75200-and-vx3-and-65161/18484/8 "2023-06-25T18:08:45Z")
</div>
When you are actually connected and remote unlocked push that button to the right of power and it will cycle between h, m and l. It displays on the right top in remote. going out to try it right now 😉
#### Post date: [June 25, 2023, 6:55pm UTC](https://foil.zone/t/power-limit-flipsky-vesc-75200-and-vx3-and-65161/18484/9 "2023-06-25T18:55:52Z")
</div>
Just tested the M setting and it just perfect for me. Full throttle just enough to get up and once on foil nice smooth control
#### Post date: [June 26, 2023, 5:17am UTC](https://foil.zone/t/power-limit-flipsky-vesc-75200-and-vx3-and-65161/18484/10 "2023-06-26T05:17:59Z")
</div>
Wonderful!!! 🙂
#### Post date: [June 28, 2023, 5:11pm UTC](https://foil.zone/t/power-limit-flipsky-vesc-75200-and-vx3-and-65161/18484/11 "2023-06-28T17:11:32Z")
</div>
Does anyone know what is limited when you switch between l, m and h?
Is it power or current or rpm or?? Just wondering how the limits of max current and power come into play to fine tune this feature.
### Author: ![lukmo](https://foil.zone/user_avatar/foil.zone/lukmo/32/35248_2.png) [@lukmo](https://foil.zone/u/lukmo)
#### Post date: [June 28, 2023, 7:06pm UTC](https://foil.zone/t/power-limit-flipsky-vesc-75200-and-vx3-and-65161/18484/12 "2023-06-28T19:06:53Z")
</div>
I think its the throttle % that changes (ppm impluse thing). In low it should only go up to something like 60%
