# Printing a propeller
**URL:** https://foil.zone/t/printing-a-propeller/19620
**Created:** [November 17, 2023, 9:31pm UTC](https://foil.zone/t/printing-a-propeller/19620 "2023-11-17T21:31:15Z")
**Showing post:** 7
### Author: ![lishine](https://foil.zone/user_avatar/foil.zone/lishine/32/29468_2.png) [@lishine](https://foil.zone/u/lishine)
#### Post date: [August 2, 2024, 12:05pm UTC](https://foil.zone/t/printing-a-propeller/19620/7 "2024-08-02T12:05:14Z")
Propeller base get broken each time near the nut after one or two rides.
Did somebody encounter this?
Printed using Overture PC 100% infill. (The bladed are totally strong)
(the color - it is just epoxy primer spray)
I had to enlarge a little the seat of the nut in order nut to fit and also sanded the base inside in order for blades to fit - so that weakened it of course.
Will try:
1. Enlarging/enforcing the area
2. Replacing nut with insert
3. Replacing m4 with m3
4. Printing with petg
 ![image](https://foil.zone/uploads/default/original/3X/7/d/7d8c41dbf08df1ed369eafebe3f5fda52d94b548.jpeg)
_[View the full topic](https://foil.zone/t/printing-a-propeller/19620)._
