I stand corrected.
However the “coming soon” marketing ploy that’s so common these days irks me.
I stand corrected.
@zesc, this is the spec from your webpage - 120amp continuous, but now you say only it’s only good for 30-80 continuous?
This rating is the reason why I bought the controller.
Again, what is your refund policy?
Hi Mark, let me PM you.
Did you get a proper response to this issue? @ZESC is silent at the moment in my case.
Maybe. waiting on a refund, but had to send the unit back to them in China.
I since ordered and are using a makerX G-300. Completely different beast. Here are some comparisons.
No response from @ZESC after 2 weeks. The customer service is a non existing service?
I sent the controller back to ZESC when I was in China a couple of weeks ago. They have received it, and now are arguing about giving a refund, saying they need to continue evaluating the unit, they have had it over a week.
Their last email was complaining how I did not send back the Bluetooth module (I forgot, it’s still in the wrapping)
If I don’t get a resolution in the next 24hours I’ll process a refund via PayPal.
Avoid this company and their products.
It’s apparently so hard to realise for manufacturers that they build both parts and their name. Can’t have one without the other and be succesful for any longer amount of time.
Hi, our engineer inspects the board. The terminal is either destroyed by external force or a loose screw which has huge contact resistance.
Here are the reasons.
BR,
ZESC.
I would guess that the liquid metal is molted solder from overheating. This could imply that the thermal measurement on this design is not at the hottest part. I’ve seen this on other designs when i borrowed a FLIR camera and checked my esc, at full throttle there was a huge delta between the temp measurement and the hotspot in the esc.
If so, then this is likely a design flaw, not a user fault as there is a temp protection on the esc, (or the setting in the VESC was too high.) This is not difficult to verify if you/we want to.
Those liquid metal on the board is still soft, definitely not solder.
Can I ask you a question.
Do you know where is the thermistor on PCBA??
No, but i hope you do?
I am not bashing your product, just stating the obvious: it’s not really likely that “strongarm” opened the ESC and poured liquid metal in it to destroy it - any problematic item or material that is there was part of the original design, don’t you agree?
The spatter that is there could be explained by overheating something, causing solder to flow freely. The terminal seems to have no solder anymore so that’s one place it could come from. If it’s not solder then it’s a bit of a mystery…
I am speculating, yes, and you know the design by heart and have it in front of you. What is your theory on the metal spatter? What is it and how did it get there?
Hi @ZESC - I assume you want to have the conversation here rather than by email.
The soft metal looking stuff is most probably thermal paste that I used between the zesc and my aluminium heat sink. This is thermally conductive, but electrically insulating so not the cause of any issue.
When cooling via thermal paste and and an upgraded thermal pad didn’t help with the cooling, a put some mineral oil in the bottom of my case in attempt to make it usable and not overheat. I was on holiday and running out of ideas. This worked great for an hour of use, the highest temp I saw was around 60°C.
On my next use of the vesc, the motor became erratic and then died 1km from shore, I’m assuming this is when the phase terminal desoldered and broke. On disassembly I had to use pliers around the phase terminal (it was completely seperate from the PCB) to remove the screw, and lug) so there was no loose connection/ high resistance here.
Zesc, you just posted some info on you new pro vesc, with a cooling set up showing it running at the stated specs. Can you do the same with the Raiden? Showing it running at 120amp continuously? With the standard pad. As shown in your spec sheet. I bought the Raiden based on your spec sheet which is a lie.
My max current was set at 100, but used approx 30-50 continuous, but the full 100 on start up to get out of the water. No where close to 120amp continuous.
Refund my money, the full amount with in 24 hours, otherwise I will open a dispute via PayPal, using your posts on this forum as evidence of selling a product that is not as described.
The heat dissipation of that one still does not look too good. (3rd and 4th image)
Correct me if I get the way this is assembled wrong, but the MOSFETs on the 3rd image are designed to put all their heat into the PCB below, not be cooled through the black housing. But as I see it, on the opposite side of the FETs are the current shunts? And the cooling is likely through the top of the FETs?
About the screw post desoldering itself, likely to overheating: I have not seen M4 SMD screw posts with more than 50A rated current… see e.g.: https://www.we-online.com/components/products/datasheet/7466004.pdf
From the first image in this thread, it also looks like the terminal that has failed was not fully covered by the thermal pad, making this likely one of the hottest areas on the whole PCB.
That paired with the fact that screw posts have a higher risk to develop high resistances mid-use by e.g. wrong tightening torque of screws, screws coming loose, wrong/insufficient mating cable termination (all compared to soldered joints) in my opinion thats just not a great joice for high-current diy applications. Except if each screw post is monitored thermally, which is not really feasible for such and application either.
Had to check on the posts but there are at least some high current solder posts in m4, like 225869-E from TE with 160A rating. Might not be what’s in the raiden, seems the high current options in m4 are unicorns.
Thats a part TE has taken over from ERNI when they bought them late '21. And ERNI actually rates their stuff a bit weird sometimes, many of their connectors rated 10A e.g. drop to below 2A depending on how you use them. Also, the geometry and solder area is way different from what Raiden uses.
Agree, the solder area and type of PCB will have a huge impact on the current carrying capacity of the lug.
At 9.5mm diameter the lug it’s self is probably more than capable of 160amp, but when soldered to a thin, non thermally conductive PCB that probably drops to 1/3 and only for a minute or so until overheats and falls off….
During EOL test, we keep running 120a load test(without heatsink) until thermal throttle kicks in. All ESC are passed. If there is soldering issue, the screw terminal will fall off in the test.
We have a customer whose PCB is carbonized but the terminal is still fine.
You are the first one who has terminal falling off.
We still choose to give either partial refund or replacement.
How long does it take for the thermal limit to kick in during your tests with the raiden7?
In my tests it was 10 -15 seconds until thermal limit at less than 100 amps, with a heat sink, with thermal paste.
Can the Raiden 7 run at 120amp continuously as stated in your spec sheet, or can’t it? If it can, show a video on your test stand like you did for the pro and state what modifications are required.
If it can’t, then give me a refund.
Btw this is a great advertisement for your company
Not going to buy one of those. My flipsky 75200 rocking my efoil all day never gets past 37C on my simple passive mast cooled setup.
