# RIWI’s third build
**URL:** https://foil.zone/t/riwi-s-third-build/7904
**Category:** Builds
**Created:** [May 19, 2020, 3:13pm UTC](https://foil.zone/t/riwi-s-third-build/7904 "2020-05-19T15:13:44Z")
**Showing post:** 6
### Author: ![Riwi](https://foil.zone/user_avatar/foil.zone/riwi/32/20684_2.png) [@Riwi](https://foil.zone/u/Riwi)
#### Post date: [May 19, 2020, 7:02pm UTC](https://foil.zone/t/riwi-s-third-build/7904/6 "2020-05-19T19:02:55Z")
For the box I made a mold in wood which a sanded with 400 grit, painted and waxed before laying up the fabric. I don’t have time for two part molds so I made small holes, three per side, through which I blow air in order to release the finished box from the mold. Works like a charm. This is the mold, you can see the first layer of peel ply.
![image](https://efoil.builders/uploads/default/original/2X/a/a024995e04aede9036682012f3fb994986615874.jpeg)
After the box is released and fitted to the board it looks like this:
 ![image](https://efoil.builders/uploads/default/original/2X/5/53487fc54621e55331d319bacfef8f23d6f52450.jpeg)
The lid is another story. I always do the lid after the board is almost complete, this will give the best fit.
I make a “plug” in eps that fills the box. I don’t make the plug flat, it’s stronger if it’s a bit curved.
 ![image](https://efoil.builders/uploads/default/original/2X/b/b8ab2b7b5ddcc83ebefe26687dddc9ff3e9d218c.jpeg)
The eps is covers with vinyl, epoxy does not stick to it.
 ![image](https://efoil.builders/uploads/default/original/2X/9/91bfe391a56548e68c6effa90781469655f6d7dc.jpeg)
After this I apply epoxy, fabric, core material and so on. I used vacuum to extract any extra epoxy and air.
 ![image](https://efoil.builders/uploads/default/original/2X/e/eefbad44cd2dd602ffb2f2e677d3353ac48ce376.jpeg) ![image](https://efoil.builders/uploads/default/original/2X/f/fda56c1fcb07a60d61d8173ef842bd127c90ee80.jpeg)
_[View the full topic](https://foil.zone/t/riwi-s-third-build/7904)._
