# Routing of 6384 motor cable inside aluminum mast
**URL:** https://foil.zone/t/routing-of-6384-motor-cable-inside-aluminum-mast/17402
**Category:** efoils – Electric Hydrofoil Surfboards
**Created:** [January 25, 2023, 1:48am UTC](https://foil.zone/t/routing-of-6384-motor-cable-inside-aluminum-mast/17402 "2023-01-25T01:48:56Z")
**Showing post:** 2
### Author: ![sat\_be](https://foil.zone/user_avatar/foil.zone/sat_be/32/35523_2.png) [@sat\_be](https://foil.zone/u/sat_be)
#### Post date: [January 25, 2023, 6:28am UTC](https://foil.zone/t/routing-of-6384-motor-cable-inside-aluminum-mast/17402/2 "2023-01-25T06:28:31Z")
Definitely on the side, try to route the cables through the mount. This is a 63100, cables enter the mast unter the plasic part.
> [@Daniels (un)geared inflatable (slowly built)](https://foil.zone/t/daniels-un-geared-inflatable-slowly-built/8069/55):
> Update: Ungeared my setup! After some trouble with a cold fused alu prop to the stainless steel shaft, I had to destroy parts of the geared motor pod. It worked well but was a bit long and heavy. I also did not want to bother about water ingress into the pod any longer, therefore I went for a 63100 run wet. coated stator and rotor with epoxy Also replaced the ESC, the Flier went up in s…
_[View the full topic](https://foil.zone/t/routing-of-6384-motor-cable-inside-aluminum-mast/17402)._
