Yes, the HW is very similar, and the advertised SW features are also very similar. The difference is that the other project has these features working and has active support, and the other doesn’t. Just like @sat_be said, good SW makes a difference.
Ok so you mean infinity logger doesn’t work as expected this is a « good point » ! Thanks
do not buy iLogger, there is big chance it won’t work as supposed (happened to me and bunch of other people). In my case it doesn’t work at all. Also, it seems that creator of iLogger ghosted, wasn’t online for almost a year on forums and doesn’t reply to messages.
hi @jkoljo I would like to know - for your expertise point of view - what is a reasonnable Wh/km consumption for an eFoil like your ? I see on your metr logs some values but I 'm looking for an average value during whole session (with start and cruising) . An approximate value of efficiency. Is 160 -190 Wh/km an bad value or not ?
Hi, the metr log shows the average Wh/km over the entire session. Typically it’s about 40-50 Wh/km for me. Over 100 Wh/km consumption is too high in my opinion.
Ok thanks for answer ! I suppose at the beginning when you learn efoil, You have more trial so more ‘full throttle start’. Kinds regards ![]()
I was reading Wh/Mi and not Wh/km ![]()
166Wh / 1.852 = 89 Wh/km. Seems better for Maiden ![]()
