The only real way to test this would be in a thrust tank. Anything else is just open to interpretation. One day if I have the time I’ll put something together but there are more pressing designs at hand at this stage.
Looking forward to seeing that, but i guess it won’t work in a thrust tank. Haven’t seen bollard pull tests correlate to real world efficiency; testing requires the proper flow and velocity around the setup.
A proper thrust tank has proper flow built in, otherwise it’s just a tank with a scale ![]()
You can start a proper thread when you build it then ![]()
