# Swabian Efoil build
**URL:** https://foil.zone/t/swabian-efoil-build/14556
**Category:** Builds
**Created:** [November 20, 2021, 12:31pm UTC](https://foil.zone/t/swabian-efoil-build/14556 "2021-11-20T12:31:19Z")
**Showing post:** 10
### Author: ![leachim](https://foil.zone/letter_avatar_proxy/v4/letter/l/43a26b/32.png) [@leachim](https://foil.zone/u/leachim)
#### Post date: [November 29, 2021, 5:29pm UTC](https://foil.zone/t/swabian-efoil-build/14556/10 "2021-11-29T17:29:30Z")
Its snowing here so i thought this would be a nice time to start my cooling similar to @sat_be s Build: [Daniels (un)geared inflatable (slowly built) - #72 by sat\_be](https://foil.zone/t/daniels-un-geared-inflatable-slowly-built/8069/72)
This solution is much more easy because a water tube could disconnect when the radius is getting to small. The Summer gonna show if the aircooling is enogh 😅 .
So i bought the biggest cooler i could find, around 300_100_20 and cut it down to 200_100_20.
After that I trimmed ~8 - 10 mm flat plane around.
 ![20211128_145853](https://foil.zone/uploads/default/original/3X/2/6/2674799b80c2a04fa0231ddbf5b30f7932b5e63b.jpeg)
Then I made a hole of the size of the cooling fins in the box.
The direction of the fins is going to be in the direction of surf. This should lead to a maximum air cooling.
 ![20211128_172902](https://foil.zone/uploads/default/original/3X/6/7/67bc35b4855162d15406f329298402173cc890d5.jpeg)
The heatsink got several screws to hold it in place. Its seals with Silicon all around.
 ![20211128_193226](https://foil.zone/uploads/default/original/3X/8/b/8b0819c82bfd0dc16735ce47ae351f43a739fbd2.jpeg)
I Placed the VESC directly on the Heatsink with some heatpaste and two screws.
The screws are also seald with silicone.
 ![20211128_193234](https://foil.zone/uploads/default/original/3X/4/9/4968c0dde7df491cef446b1bbe63d681f5c37d1a.jpeg)
It looks like its all Waterproof 😁
 ![20211129_103835](https://foil.zone/uploads/default/original/3X/a/8/a8fd39a833ca742497254bed9d4201914190ed52.jpeg)
Made some Isolation with some rubber from a bike tube. And placed all the components and made some nice cabeling. The placement of the components is pretty nice. If water comes in they stay dry a long time. But the batterys gonna melt 😇.
 ![20211129_175052](https://foil.zone/uploads/default/original/3X/c/6/c6ef58c4424ff53cdec272b67b00808131b99152.jpeg)
The edges of the heatsink are really sharp. If i fall i directly fall over it. So i Made some PETG protection frame around it. There will come an aditional one for the screw of the VESC.
 ![20211129_175113](https://foil.zone/uploads/default/original/3X/c/0/c0ebe36cbddac57cfb06013bcf4fa184dfebc5be.jpeg)
So next steps gonna be:
1. Test it 😃
2. replace bearings
3. replace the old mastmount with the new hydrodynamic improved version.
_[View the full topic](https://foil.zone/t/swabian-efoil-build/14556)._
