Let’s talk batteries. I know cylindrical is the way to go but I like it simple
Just got my hands on 12 li-ion cells from a banged up Kia Soul. Cells are 42,5ah 4.2V and the weight is 750grams. They can handle 10C without generating to much heat.
Made a prototype for water proofing my XT150 connectors that will be placed between the mast and the board. I use two lip seals 4x12x6mm and a o-ring 19.5x3mm togheter with a 3D-printed shell with threads. Its a very tight fit for my 10Awg wires. I used a bit of oil in order for the shell to “spinn” on the wires. I think 4,5mm would have been better but i didnt find any.
There is no room for the plastic covers that come with the XT150 inside the housing.
I will add the STL if the overnight test is successfull.
Hmm, yes that would make it much easier and faster to print. Threads are demanding and requires some after prep to work in a good way. I like the lip seals. Thinking about using the on the “board side” as well. 3d print a “wall” with three pockets for lip seals. Epoxy the wall to the board and you have a water tight cable gland that requires minimum space.
