Alexandre, You may have heard of that sealant ?
interesting thank you!
Hello
Did you find time to test it?
not yet, still working on the board, i take my time, the water is a bit cold still in Lyon
I understand… I’m from switzerland (french parts) and the lake is effectively cold
Last thing missing for saturday test, 4 degree correction for mast and for the câbles as well
next year it will be more like this
That looks slick and great idea to get the ESC cooling directly from the mast and mast plate. And would the whole mast/ESC box unit be removable from the board? Only then have to worry about power/PWM connection to the ESC.
pic from the fliteboard , great idea!
hej. Could you give me the link where you bought the motor and gearbox.
Also do you think this this gearbox:
https://www.reisenauer.de/artikeldetails.php5?aid=1416&sprache=2
Would fit with this engine and have enough Power: Peggy Pepper HK-2221/4 6000KV
This motor is appears to be an outrunner, those are harder to cool than inrunners.
the first link is the gearbox i have : chief 6:1 4p
the second link: this motor is not powerfull enough and spin x10 too fast , it is 6000kv you need more like 600kv on 12s and 800kv on 8S
i have a tp power 4070 V1 with 780kv running on 8S
or one of those:
i m testing this step up tomorrow …
Everything went well , play around 40min , getting better but it is very hard to stand up 100l board … Need more training , stop at 3,89v on 32a 8s …
Try post the video
Thx for the tips.
I will order the TP4070-V1 6Y with 780kv with the MOTOR-CHIEF 6:1 4P gearbox.
But probably will run em on 12S batteries.
I just saw your pictures it looks awesome. Do you have any estimate how fast it goes with 8S batteries?
Btw what happened with the propeller?
not fast enough but i have to analyze the log from the esc, i was spinning around 2800 rpm on load instead off 4300 i had a lot off water in the pod , i played around 1H before losing the propeller , i would say it feel like around 20km/h but i had a hard time to stay out of the water, the board is too small or i am too heavy i guess
i will put down the number i got from the esc but there is something wrong because i pull 180a max (on a 125A motor) and average 100A recording, but for the battery it is 22A for more than 1 hour off messing around, never was standing up
and the funny one, time to change place
Bravo Alexandre, super !!!
It’s definitely fast enough to foil! The issue you are having is because you are on your knees. When a lot of people learn to surf they try to get to their knee’s before they stand, this leads to a massive amount of instability and makes it harder. It’s much easier to go from lying down to your feet as fast as possible. Once on your feet you have a much faster reaction time and will stabilise the board better…
Sorry that you lost the prop!
@philgib: merci !
@Jezza: yes i know but i didn’t want to hurt myself the first time, i know wakeboarding, flyboarding but not surfing…
so things that went well:
things to work on:
