# Volker’s Build - 80100 18650-30Q
**URL:** https://foil.zone/t/volker-s-build-80100-18650-30q/4796
**Category:** Builds
**Created:** [June 26, 2019, 11:27am UTC](https://foil.zone/t/volker-s-build-80100-18650-30q/4796 "2019-06-26T11:27:20Z")
**Showing post:** 16
### Author: ![V\_S](https://foil.zone/user_avatar/foil.zone/v_s/32/6616_2.png) [@V\_S](https://foil.zone/u/V_S)
#### Post date: [July 20, 2019, 2:46pm UTC](https://foil.zone/t/volker-s-build-80100-18650-30q/4796/16 "2019-07-20T14:46:59Z")
**[80100](https://alienpowersystem.com/shop/brushless-motors/80mm/c80100-outrunner-brushless-motor-80kv-7000w/)**
The APS got only a slight touch up:
Some magnet gap filling, and a coat of epoxy.
Shaft shortend with angelgrinder on a lathe.
 ![IMG_20190719_210453](https://foil.zone/uploads/default/original/2X/c/c31a35c3eff705e19860d5fc081deb1a0f1b5967.jpeg)
Stator same. One coat with epoxy and shortend the wires.
 ![IMG_20190719_232333](https://foil.zone/uploads/default/original/2X/c/ca916bc17b6e5d7539302e70611af9fdd3165e8c.jpeg)
Bearings will be switched later to open ones
[Jump](https://efoil.builders/t/volker-s-build-80100-18650-30q/4796/35?u=v_s) to Bearing drama
Update:
Switched to these beautys:
 ![IMG_20190816_123954](https://foil.zone/uploads/default/original/2X/0/0ce23b836da25809b86bf272e5a9b6327155757e.jpeg)
3 6801 12/21/5mm
1 6809 45/58/7mm
_[View the full topic](https://foil.zone/t/volker-s-build-80100-18650-30q/4796)._
