I potted the motor with epoxy similar to the way many on the forum do. I would say it would be borderline enough power at 95kg. It would probably only work on a large wing over 1100cm.
I’ve been running a 14S2P for 6 months or so with the sequre 14200M and it works a treat. Too much power really. 14S1P was next on my list but I’ve been distracted by these Racepow ‘semi solid state’ packs that I know nothing about - but the claimed energy density makes a 14S1P pack with standard 21700 cells less appealing.
How you make the leash longer than the straightened spiral cable?
I see that your leash is a regular rope. Or is it flexible…
It has a small section with bungee inside of dyneema rope. This allows a small amount of extension when you fall.
The bungee inside dynama rope is a product I can buy? Do you have a picture?
It came from one of these that had a broken coil. You can also make them by looking online. People put their own stretch cord inside of dyneema.
Hi Tim,
With reference to your CLINKO balance set up: did you use a basic balance lead cable and solder the CNLINKO on to it?..or did you use something else other than the JST type connector at the charger end?.
Many thanks
Mark
Great setup .
Liking that lightweight motor, could work for my 70kg i think.Front pattern should fit same pod as flipsky 6374/old 6384 right?. (30mm holes)
Is that a 3d hub?.Are the .stl files available?.I guessyou just remove the rear attachment o expose the holes and cut the shaft.
Thx!
I just made an adapter for the charger. The adapter has the JST on one end and the CNLINKO connector on the other. I made it from a 12s JST extension.
The motor has the same bolt spacing as the foil drive gen 1 motors and the Baud 6384 motors available online. This is slightly different from the original Flipsky 6384 motors. I can’t remember the exact hole spacing but can take a look when I get time. From memory I believe the mounting side was the same but the prop hub side was different.
The prop hub is a two blade foil drive hub. You can find them online for a deal as most people want the three blade setup.
Tim
Hi - I had a question on the nolimitz mast and mounting the pod - the FD integrated masts that nolimitz made had a wrap-around big cone that was simply glued to the mast with some king of semi-soft glue. What did you use to attach your cone? Did you drill through the mast? Thx
The mount I made is drilled thru the mast and attached with two bolts. The outer side covers slide into place from front to rear and are held on mechanically.
How did you insert the 4 nuts into your PETG print? Is it really solid ?
Your setup looks perfect
They are inserted from the inside before the battery is placed into the box. Then covered with a sticker to keep them from being exposed to the potting resin.
