Hi all,
I have been reading this forum for a while and I am about to start my first DIY assist build. I would love some advice from people who’ve done it.
About me and my gear:
- Wingfoiler, 88kg, flying and going upwind, still learning jibes
- Board 1: Gong Hipe 115L inflatable (an inflatable is a fixed constraint for me)
- Board 2: Takoon Escape Air 8.0
- Foil: Gong 85cm alu mast, Curve H V3 XL and Ascent XXL front wings
- Spot: choppy onshore spot in Greece
My goal is to get better at wingfoiling, although e-foiling capability would be great!
Main goals at this point:
- Assist for take-off on light wind days
- Practice without the wing on no-wind days: carving, foot switches, pumping (as much time as possible of flight would be great)
Planned setup (waist belt/backpack):
- Motor: Flipsky 6384 140KV waterproof, 2-blade folding prop, mounted high on the mast
- ESC: Flipsky 75100 aluminium PCB (84V), in the belt box together with the battery, with an external heatsink
- Remote: BREmote V2 (or Flipsky VX3 pro)
- Box: small IP67 box on a waist belt with quick release
- Cable: about 2m LAPP OLFLEX 3G2.5 PUR to the motor, with a non-stretch leash slightly shorter than the cable
- Kill switch: XT90-S loop key on a lanyard
- Motor mount: 3D printed
Battery: a friend builds packs and will make it for me. He has standard 21700 cells (about 5Ah, 15-17A continuous) and some power cells. I’d limit battery current in the VESC to about 32A (about 1.5kW, similar to Foil Drive). Options:
- 13S2P with the 5Ah cells: about 10Ah / 470Wh, about 1.8kg
- 10S3P with the same cells: about 15Ah / 540Wh, about 2.2kg
- 13S2P with power cells (P42A type): about 8.4Ah / 390Wh, about 1.8kg
- You tell me!
Questions:
- Which battery would you choose in my position, and why?
- Is about 32A (13S) or about 42A (10S) battery current enough to get 88kg up on an inflatable with these big wings?
- Anything in this setup you’d change, especially for a waist belt used with a wing (cable routing, leash, quick release)?
- Folding 2-blade or 3-blade prop for this use?
Thanks a lot!
