# Which remote should I buy
**URL:** https://foil.zone/t/which-remote-should-i-buy/13479
**Created:** [August 16, 2021, 9:17am UTC](https://foil.zone/t/which-remote-should-i-buy/13479 "2021-08-16T09:17:12Z")
**Showing post:** 2
### Author: ![heddan99](https://foil.zone/letter_avatar_proxy/v4/letter/h/b2d939/32.png) [@heddan99](https://foil.zone/u/heddan99)
#### Post date: [August 16, 2021, 6:38pm UTC](https://foil.zone/t/which-remote-should-i-buy/13479/2 "2021-08-16T18:38:30Z")
Do not do The misstake and buy Vincents remote that i did in The spring just.
I still have not got mine working, if The sender/receiver is broken or What is The reason for The problem I have i do not know. But i really regrett that i spent so much money on something that is not working. I could have bought four maytech remotes instead that is working without any issues in my setup and they are lasting at least one season before they give up and hopfefully longer.
> [@Loses signal underwater - First test: FAIL!](https://foil.zone/t/loses-signal-underwater-first-test-fail/13246):
> Hey guys - Got my whole setup built, went out to test it today in the ocean, and the moment the battery box is under the water at all the remote loses it’s connection. Maytech MTSKR1905WF V2 IP67 Waterproof Remote I see others have had a similar problem. Anyone have a solution? Is there a way to extend the antenna? Also, does anyone know of a waterproof wired remote? My setup is different so it could actually be wired in place.
If you are not in hurry and need a remote directly i would wait to see What wushbush testning of some new remotes results in.
Hopfefully it will Come out some good watersealed remote soon that is working well.
_[View the full topic](https://foil.zone/t/which-remote-should-i-buy/13479)._
