Use NMOS to realize switching on/off Power positive
Switch comes with LED light indicator;
Shutdown current less than 1uA;
Suitable for load: three phase motor speed controller;
Boot soft start;
Automatic short circuit protection when boot;
Automatic short circuit protection when work.|
Why don’t you send one or two of these to users on this forum so that they can trial these in a real environment and see how they hold up. If they work well I’ll bet you’ll get loads of sales!
1. Specifications:
| Brand | Maytech | Model Number | MTS2009AS |
| Application | Electric Skateboard, Efoil, surfboard, boat, motorcycle, etc | Connector | Ring Terminal |
| Max Current | 300A | Voltage range | 20-85V |
| Max voltage | 85V (20S lipo) | Color | Black |
| Switch Type | Use NMOS to realize switching on/off Power positive | Size | about 97x56x25mm |
| Features | Switch comes with LED light indicator; | ||
| Shutdown current less than 1uA; | |||
| Suitable for load: three phase motor speed controller; | |||
| Boot soft start; Automatic short circuit protection when boot; | |||
| Over temperature protection (The switch Mosfet PCB exceeds the rated value of 110℃ for more than 1s), which is equivalent to overload protection; | |||
| Automatic short circuit protection when work. |
2. Wiring:
Check video of how to crimp the ring terminal to cable:
How to Crimp Terminal Connector to Wire for Maytech 300A Anti-spark Switch
3. LED indicator:
LED Idicator on , Normal working condition;
LED I ndicator slow flashing , Startup fail. Possible reasons: “voltage lower than 19V, the load is short-circuited, the load capacitor is too large, the load type is incorrect, the load is short-circuited during use”.
LED I ndicator quick flashing , Over temperature protection (Mosfet PCB temperature is over 110℃ for more than 1s to start the protection). Please turn off the switch and restart when temperature is lower than 110℃.
Hi, is this product CE rated ?
