hello, I am going to start making the efoil with a 6384 engine.
I have a question before starting, I saw in certain messages that you could use CORROSION X by bathing the engine components in it.
I would like to know if it should be done with the 3 stripped phase outputs?
What other products can I use instead of CORROSION X because I can’t find any in my country, nor Wurth or Crc6-66 marine?
Thanks for your help.
