Which is more preferred? Threaded or splinded?
I have the threaded version. I think the threaded version is heavily favored because it will be much easier to get propeller options attached. With the splined shaft you will need to get a prop that has the appropriate spline fitted. Or you would have to go messing around trying to press fit a spline into a prop. Iâm not sure if any proper efoil props even have this spline option. The main option Iâve seen is the aluminium one Flipsky/others would sell with the motor. This prop has been discussed on the forum quite a bit and doesnât seem to be very good for efoils. Some people have cut it down and report it works better, but I donât think thatâs worth doing when better options are available.
The wind is turning: MicHobby is now offering a new prop looking like a FR prop with 65161 so other sellers should follow.
@SoEFoil Do you have a link to this product please as I could not locate it?
Having had the pleasure of trying to get warranty from freerchobby on several occasions i donât recommend them - for anything.
I got my money back purely due to paypal as they tried their best to avoid responsibility.
My mistake, it wasnât FreeRCHobby but MicHobby on the Hobiba thread promoting a Maytech motor (obviously praised for not following the Flipsky way):
'Makeup work for the absence of Flipsky version 65161 on DIY market - #13 by ChrisZ
Will you find the âfree propâ error ?
- MTI65162-120-SF thread shaft without propeller: 300usd
- MTI65162-120-SF thread shaft with free 150mm propeller: 346usd
The blade surface quality is not exactly the FR one though.
Here 'Maytech Hobbica 65161 65162 Electric DIY Efoil Hydropfoil Surfboard Fu â MICHOBBY.COM
Hobbica / Hobiba: confusing isnât it ?
This is the link to the prop. I agree âplasticâ prop looks pretty rough. I would rather use the cut down aluminum prop created from the too big prop that has been the standard âincludedâ prop
Fliteboard prop is a LOT more refined for the same price.
[OffTopic butâŚ] Wondering about their ESC stated as â160A cont IP68â compatible with the Maytech remote. Would fit nicely above a mast plate box in the @okp styleâŚ
Has anyone tried this propeller on a 65161 on aliexpress? Looks better than the boat prop.Processing: 1000016081.jpgâŚ
Yes. Is it any good for 65162 motor 120kv motor
