Hello,
I need some help! I’ve been building a foil the last year, Started with a geared setup and changed to Flipsky 120kv and 200amp VESC. I’ve purchased 144 Samsung 25R batteries and I plan to build 2 - 6S12p packs and charge with a Hobby Balance charger. My question is about the nickel strip. For the amount of current that a foil will need will .15 by 18.35mm be enough between cells (in a honeycomb format) and .30 by 18mm for the positive and negative sides? Any advice would be greatly appreciated.
Thanks, Dan
